It is currently Fri Aug 01, 2025 10:51 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed May 02, 2007 1:41 pm
A+ ones are noisy?
but non A+ are hideously noisy..
PostPosted: Wed May 02, 2007 1:43 pm
As in... they don't mesh properly.
PostPosted: Wed May 02, 2007 2:07 pm
As in, no you can't without causing damage.
PostPosted: Wed May 02, 2007 2:08 pm
But he can try :lol:
PostPosted: Wed May 02, 2007 2:29 pm
so whats good about a gemini starter?
PostPosted: Wed May 02, 2007 3:04 pm
More reliable, doesn't 'kick off' when trying to start, if your ring gear is buggered it is OK cos it engages from the other side (i think).
Mine spins the 1275 with ease about twice as fast as ye olde lucas did.
Ummm...
So is better.
PostPosted: Wed May 02, 2007 3:08 pm
cool, what about noise?
PostPosted: Wed May 02, 2007 3:15 pm
I don't know how long it takes for your car to tick over but it sounds like you have other serious issues if you're worried about the prolonged sound of a starter!!
PostPosted: Wed May 02, 2007 4:21 pm
nobody said anything like that
PostPosted: Wed May 02, 2007 4:33 pm
Sounds like a starter motor.... :wink:
But no whirring from a worn out bendix gear, and no noise as it tries to engage and doesn't. No extra noise as it tries to start then disengages the first time one spark plug fires.
A rebuilt lucas would probably work fairly well too, although I have been told that if your engine has trouble with cold starting, the inertia starter isn't as good even if new.
PostPosted: Wed May 02, 2007 4:34 pm
The starter is only ever on for a few seconds, why would the noise of it ever be a problem unless its like a jet engine starting up??
PostPosted: Wed May 02, 2007 5:35 pm
If you fit a Pulsar dizzy the starter will not have to work as hard. :wink:
PostPosted: Wed May 02, 2007 5:37 pm
I have a late model starter from A+ and it is no more quieter or noisier than Graham's gemini ones.
Here we are arguing about noise when we all want to put in big webers and 2" exhausts... :roll: If you are worried about starter noise then you better start thinking about quiting your auto hobby...
$70 cheaper too
Lillee - 1969 Morris Mini K
PostPosted: Wed May 02, 2007 5:45 pm
Probably the same people that ask "where can I stick a sub" :D :D :D
PostPosted: Wed May 02, 2007 7:32 pm
$70 cheaper too
Yours is an aftermarket pre-engaged starter, not an A+ one.
A+ takes a different size ring gear.
