It is currently Tue Aug 05, 2025 12:38 pm
PostPosted: Sun May 06, 2007 8:26 pm
Periodically grey wouldnt start, then would start. Now just no start. Engine wont crank over, sounding like not enough power. Battery, starter, coil is all ok, Any other suggestions so i can stop clutch startin. Cheers.
PostPosted: Sun May 06, 2007 8:37 pm
Checked the points gap lately?
PostPosted: Sun May 06, 2007 8:40 pm
Solenoid?
PostPosted: Sun May 06, 2007 8:42 pm
i dunno why but i had problems with molly once. poeple on here sugested putting her in gear and rocking her back and forth then trying again, molly started. i did it a few times and within a week she was the same again.
dunno if this is the same prob though.
PostPosted: Sun May 06, 2007 8:52 pm
I is a mookenik
well if thats the problem uve chiped a tooth on the fly wheel, which is why u needed to rock molly, if u having the same problem, with grey when u try to turn it over do u hear a clicking noise?
just ran downstairs and tried that, it didnt work. :lol:
PostPosted: Sun May 06, 2007 8:53 pm
well molly is working fine now, and i don't think anything was repaired.
floor start or solenoid?
PostPosted: Sun May 06, 2007 8:54 pm
I is a mookenik
do u have to clutch start grey all the time, do u hear a click noise every time u turn the key?
PostPosted: Sun May 06, 2007 8:57 pm
Nah, the Lucas starters sometimes get a bit sticky. If someone oils the starter it will build up crud on the bendix and gum up the works. then the starter will just jam and not start and not throw out. You rock the car in gear to get it to disengage.
If the solenoid is crook you turn the key and nothing happens. Not a sound.
PostPosted: Sun May 06, 2007 9:16 pm
floor start, yes now i have to clutch all the time. only sound is car wanting to turn over very slowly, then nothin
 Post subject: Bendix
PostPosted: Sun May 06, 2007 9:26 pm
Is it the original battery :?:
Bendix gears also get hooks on them from smashing into the ring gear...they can get hooked up and not let go....put it in gear and rock it back and forth.
PostPosted: Mon May 07, 2007 11:11 am
Any joy yet?
Sounds like poor cable connections to me - all those currants aren't a gettin to the starter!Check your connections to see if they're loose, dirty etc. Also the obvious ones - battery posts. Check battery volts - should be about 13.5 fully charged.
Wouldn't mind betting the battery is down on amps.
Last time I checked my battery terminals,I thought to myself - wish my wife was this dirty :P
PostPosted: Mon May 07, 2007 11:14 am
Can you clutch start it? If you can then its starter or supply to starter.
PostPosted: Mon May 07, 2007 11:22 am
had similar prob for a while. Thought all was good even starter!
Turned out to be the starter as it had obviously been worn. It would take as much charge as it could but not turn the engine properly. Swapped it out and now good as new! :D
(\_/)
(O.o) <CoPy> <) MaY oBtAiN wOrLd DoMiNaTiOn.
Users browsing this forum: Bing [Bot] and 92 guests
