It is currently Sun Aug 03, 2025 12:21 am
PostPosted: Fri May 18, 2007 10:25 am
What size spanner do i need to buy to fit the damn thing?
PostPosted: Fri May 18, 2007 10:35 am
If you mean the large one on the front subframe then it's 15/16
PostPosted: Fri May 18, 2007 11:09 am
The end that goes into the drum backing plate...might be the same size?
Are the hose fittings the same for disc and drum?
PostPosted: Fri May 18, 2007 11:13 am
PostPosted: Fri May 18, 2007 11:22 am
No that's a different size, 5/8 spanner, but it's a bad fit usually.
PostPosted: Fri May 18, 2007 11:27 am
:lol:
"what size is that nut?" .. "shifter size"
Shifter isn't good on the real stubborn ones....
Hmmm...my 5/8 is too big? it's a wierd size..might be whitworth?
PostPosted: Fri May 18, 2007 11:35 am
Yeah, I'm not sure about the spanner type, might be right about whitworth or some other archaic AF size.
Good thing about the old hoses is that as they are usually crapped, i don't mind going them with a vice-grip if I'm throwing them out and that way avoiding the nastiness :)
PostPosted: Fri May 18, 2007 11:43 am
Sounds rough i know, but i usually use a pair of Vice Grips before even attempting the spanners.
If you get a good solid grip the first time then you avoid damaging the hoses. Always seem to use the spanner, then end up using Vice Grips anyways.
Seems to work for me.
PostPosted: Fri May 18, 2007 11:44 am
Yea...i had to vice grip the last one and want to avoid that... :lol:
Surely someone has the right tool :lol:
PostPosted: Fri May 18, 2007 12:46 pm
I've got a wierd old spanner that fits, I think it's a 5/16W Whitworth?
Would not be sure though till I get home!! 8)
Sir Alec! we are not worthy!
PostPosted: Fri May 18, 2007 12:53 pm
Im sure i managed to get a 15mm spanner onto it.
PostPosted: Fri May 18, 2007 1:26 pm
I tried before to use a 15mm for shits and giggles . At least on my set of old old old old hoses, 15 mm won't quite do it, it seems a poofteenth to big to get the spanner over. But with some malice and a hammer.....
PostPosted: Fri May 18, 2007 2:50 pm
High heel ninja
I've got the right spanner for the job if you still need it Josh.
Doogie
PostPosted: Fri May 18, 2007 3:03 pm
That's Cool, i got it off but sick of not having the right tool...you don't know what size yours is?
PostPosted: Fri May 18, 2007 3:08 pm
:roll: Just get an old 15mm spanner (they fit nothing anyway) and file it until it's a neat fit. 8)
