It is currently Fri Jun 27, 2025 8:47 pm
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun May 20, 2007 11:29 am
havent updated in a while, the engine is now finished and been running for 3weeks without a hassle , heaps more power avaliable , and great low end torque too.
engine made 139.8hp at the flywheel on graham russel engine dyno at 10psi boost , so thats an increase of 42.8 hp from last time with 4psi more. :D
engine then produced 102.8hp at the wheels at MRC at the aumini dyno day, so im extremly happy. Who needs big bore :P
heres some pics
PostPosted: Sun May 20, 2007 12:20 pm
Very nice, those figures are very impressive. 8)
But you should clean or at least matt black that wiper motor. :lol:
PostPosted: Sun May 20, 2007 2:06 pm
Give Ash some flowers Nick .
That is very impressive. All that hard work is paying off.
PostPosted: Sun May 20, 2007 2:39 pm
To those unlucky enough not to live in Sydney, this car is proof that turbocharging the A-series is the most cost beneficial mod you can do in terms of getting usable power.
It sounds great and as it should be, well done
Daniel
PostPosted: Sun May 20, 2007 3:33 pm
And complements to you Ben she sure does look the Goods also. You most of the work yourself. You recond you would build one for some one else also :wink:
PostPosted: Sun May 20, 2007 9:09 pm
Yea, well done Ben, absolutely amazing beast. I can't wait to see how many turbo small blocks get built because of you :D
PostPosted: Sun May 20, 2007 9:44 pm
ur a clever one ben. good work buddy :D
PostPosted: Sun May 20, 2007 11:26 pm
you're work is amazing ! that thing a certainly a weapon! haha
me = impressed :wink:
PostPosted: Mon May 21, 2007 1:19 pm
nice power. just wondering how fast it accelerates? 0-100 or quarter mile? if u know or would like to guess haha
PostPosted: Mon May 21, 2007 2:02 pm
I guess he will find out at the drags in August :wink: :arrow:
PostPosted: Mon May 21, 2007 4:03 pm
well done ben 8)
im sure it will make it up Lapstone hill much easier now :lol:
57 Morris minor
88 Rover Mini
PostPosted: Wed May 23, 2007 10:19 pm
Awesome work Ben, great numbers & neat install. Image
Would love to know what other internal mods are done to this little beast?!?
Go the 1100 :twisted:
Carl
PostPosted: Mon Jul 02, 2007 8:25 pm
i so want one. mmmmmmmm turbo
i like to drive on rails
PostPosted: Tue Jul 03, 2007 8:00 pm
here ya go :wink:
1098 a-series block bored 60+
hypatec 60+ pistons , hastings rings
std conrods lightened + balanced
balanced crank
lightened flywheel orange dot clutch (all balanced)
RE-13 T graham russel cam
Titan vernier adjustable belt drive kit
12g295 head with hardened seat 1100s valves turned down ports +chambers std
std pressed steel rockers
custom one off ceramic coated exhaust manifold + 2'' dump pipe
T2 turbo rebuilt + hi-flowed
Std metro turbo carb + manifold BDD needle and nics stainless plenum
300zx intercooler with plazmaman custom piping
turbosmart vee-port blow of valve
greddy profec spec b electronic boost controller
megajolt ingnition custom 8.8mm top gun leads
gearbox is std rebuild with hardened diff pin + cetral oil pickup
PostPosted: Fri Aug 31, 2007 11:08 am
hi ben!
just wondering what sort of fuel pressure regulator and pump you were running?
thanks,
- tom
