It is currently Sat Jul 19, 2025 1:16 pm
 Post subject: mixing carbys?
PostPosted: Sun Jun 03, 2007 2:04 pm
I is a mookenik
ok i got my original carby back from mini king the uk model with the float at the bottom i measured that one and the one they gave me which is an ozzy one and they measure to be the same size... i was think instead of reconditioning the 1.5 uk model and putting it back on tiny would it be possible to get them matched with the same jets springs and floats and use them as a twin 1.5 carby set up on a 1100.
its juz a thought?
PostPosted: Sun Jun 03, 2007 2:44 pm
yep keep it a thought :wink:
i think u cantnot use them as they wouldnt have the right linkages :?:
PostPosted: Sun Jun 03, 2007 2:46 pm
I is a mookenik
true lol didnt think of that, oh well, still would any 1.5 tein carbs work on a 1100 without modding
PostPosted: Sun Jun 03, 2007 2:52 pm
twin 1.5 su's are a overkill on a 1100
morris maina over here has a 1420 stroker and that has more then anuf power with twin 1.5 su's so on a 1100 its over kill unless u got a TOTALLY worked 1100 :wink:
prob not without moddin them also :!:
PostPosted: Sun Jun 03, 2007 3:02 pm
I is a mookenik
hmm well all i know out of my motor according to previous owner that it has a cam, the heads been decked and extractors, hmmmm might over kill it a tad
PostPosted: Sun Jun 03, 2007 3:06 pm
To get the greatest benefit from twin 1 1/2's you'd need some good head work , make it easier to get all the fuel/air into and out of the head quickly . You say it has a cam ( :lol: ) ,I'd be seeing if you can get more info from the previous owner as to what type of cam , is it a little better than standard or a lot better , if you're going to fit twin 1 1/2's and gas flow the head you'd be better with a good cam to take advantage of the extra fuel/air that's available . On a standard 1100 twin 1 1/2's could be a bit big but with a bit of work to the head they'd be alright .
PostPosted: Sun Jun 03, 2007 3:07 pm
agreed just get it onto a dyno and get richer needle into it
my stock 1100 runs a 1.5 su and extractors and a h6 needle
use to run a no.7
they are two a few of the richest needles for a 1100 without makin it a custom needle :wink: thats with a stock 1100 for some reason it needs to run rich :!:
PostPosted: Sun Jun 03, 2007 3:16 pm
I is a mookenik
i think from memory it had a re13 cam i think, the engine and mods were done by mini clinic so i might have to find out off them whats been done, cause the previous owner isnt even sure cause she bought the car the way it was
PostPosted: Sun Jun 03, 2007 6:56 pm
So you have had two different carbies on the car it has never run right so if you fit both at the same time it will...
1) Run twice as good.
2) Run twice as bad.
Your guess is as good as mine. 8)
PostPosted: Sun Jun 03, 2007 8:58 pm
I think its a good idea, I would suggest fitting them. Get someone with no SU carb experience to fit/tune, then that way there will be one less unroadworthy mini on the road.
Users browsing this forum: Bing [Bot], Foxy1971 and 66 guests
