It is currently Fri Jul 18, 2025 1:54 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Wed Dec 15, 2004 9:32 pm
bnicho wrote:
Mine has hotwires. Ex Moggy Minor, so they havethe correct stud pattern.
BTW you really should not put Gemini wheels on your Moke. Moke (and Mini) stud pattern is 4" PCD or ~101.6mm and uses 3/8" studs. Gemini (and Honda etc, lots of Jap cars) uses 100mm PCD with 12mm studs. While the Gemini rim will fit on due to the smaller stud diameter on the Mini/Moke, the nuts will not be centred over the stud hole. Hence the nuts can work loose quickly and/or the wheel crack around the stud holes. Believe me, I've seen it happen!!!
And if that's not enough, the wheel studs can fatigue and break. :cry:
PostPosted: Thu Dec 16, 2004 10:16 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
duc i've got a chainsaw :twisted:
makka
PostPosted: Thu Dec 16, 2004 12:08 pm
68matic wrote:
brad i just saw the moke shorty
i like very much
what are the problems in owning/converting/registering one of those?
coz ive taken an angle grinder to my moke,
and once i get my hands on a chainsaw...
i wouldnt have a clue mate, just found the pic on the net, id say it would be a case of cut and shut in the middle. Wouldnt be to hard, not sure how long it would last though. It would have to get engineered as the wheel track has been changed.
1974 Moke - 998cc
PostPosted: Thu Dec 16, 2004 1:39 pm
gafmo wrote:
Guess hwere this one was...NSW
By the look of the photo, it would have to be Mini and Moke World, the Brookvale Sharks!
:D
PostPosted: Thu Dec 16, 2004 6:12 pm
it was a private sale
so perhaps brookvale didnt touch it
btw they wanted $18k on the site,
then $16 on ebay...
Inconspicuously Conspicuous
PostPosted: Thu Dec 16, 2004 8:17 pm
That shorty Moke cannot be a real Moke - look at the size of the engine cover. No way an A series would fit in there!
I reckon someone has made a replica Moke body on a golf cart or kidee car chassis and adapted Mini wheels to fit.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
