bnicho wrote:
Mine has hotwires. Ex Moggy Minor, so they havethe correct stud pattern.
BTW you really should not put Gemini wheels on your Moke. Moke (and Mini) stud pattern is 4" PCD or ~101.6mm and uses 3/8" studs. Gemini (and Honda etc, lots of Jap cars) uses 100mm PCD with 12mm studs. While the Gemini rim will fit on due to the smaller stud diameter on the Mini/Moke, the nuts will not be centred over the stud hole. Hence the nuts can work loose quickly and/or the wheel crack around the stud holes. Believe me, I've seen it happen!!!
And if that's not enough, the wheel studs can fatigue and break.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
