It is currently Fri Jul 18, 2025 4:15 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Jun 17, 2007 11:45 pm
there is a lot of 'fluid' around it... :shock:
PostPosted: Mon Jun 18, 2007 2:12 am
well.. i did try to hide the evidence.. :oops:
PostPosted: Thu Jun 21, 2007 1:28 am
ok guys im having some trouble.
this is what i think i need to do.
take the trumpet looking thing of the rubber cone.(HOW?)
then the hi-lo sits ontopp of the rubber donut, then the little "balljoint" thats on the end of the trumpet has to be taken off and put on the bolt end of the hilo???
thsx in advance guys.
heres a pic of the trumpet
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Jun 21, 2007 1:34 am
Lots of WD40 with the straw bit and get it in between the cone and the trumpet - A BFC (Big ******* Chisel) and a BFH (Self Explanatory) and belt away....
Failing that i usually buy new cones/better second hand ones so i don't try too hard...last set i did a couple of weeks back..on one the cone wouldn't come off on the other the knuckle had rusted to the trumpet..
Your cone is quite worn and i would recommend finding some better ones...
Also i hope you have new knuckle joints as well? - the rubber on yours is rooted and i'm sure the nylon cup would be worn by the looks of it...
New vs old...
PostPosted: Thu Jun 21, 2007 1:35 am
Spaceboy wrote:
harder than removing the trumpet from the cone is removing the ball from the trumpet, but spray wd40 and hit it from inside the cone with a long object and hammer oh and hold the trumpet in a vice while you do this.
use two flathead screwdrivers on either side of the cone to lever the trumpet off, it isnt held in there by anything but its a tight fit.
PostPosted: Thu Jun 21, 2007 1:43 am
so the new ones are higher still 8)
are these available from say minisport or similar?
will i have to break the piggybank??
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Jun 21, 2007 1:48 am
Yes and it will ride and handle better too ;)
Yes..unfortunately not cheap! about ~$90ea corner..
Saves you having to stuff around splitting them...
This is what i put in my car...all new 8)
Minisport are probably the closest to you...
Karcraft up here is cheaper though..
PostPosted: Thu Jun 21, 2007 1:54 am
purfect looks exactly what i need, now to save!!!
the 3 bits, they just sit together? no glue or anything?
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Jun 21, 2007 2:11 am
yup - whole lot is held together by the tension of the cone and assembly pressing against the top arm.
With a new knuckle joint they don't come with much grease in them new - best to add a bit more chassis grease before you put them in the car ;)
PostPosted: Thu Jun 21, 2007 1:19 pm
Slow-Po
cheers jamie
Or get a set of late model Rover ones from Brickworx.
PostPosted: Thu Jun 21, 2007 2:07 pm
cheers jamie
not a bad idea ill pm steve and see what he has to say
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
