It is currently Mon Jul 28, 2025 2:50 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 22, 2007 9:31 pm
Yep I have 20 of them...just not sure how I will post them yet...strong little sods they are
PostPosted: Fri Jun 22, 2007 10:34 pm
:oops: Are the magnets inside the filter or attached to the outside and the "powerfulness" holds metal particals against the oil filter wall? :oops:
PostPosted: Fri Jun 22, 2007 10:44 pm
Normally put on the outside and they trap the super fine bits of swarf in the filter against the metal casing rather then lettng them flow around again . I've had a motor drop a thrust washer into the gearbox and reduce it to superfine metalic sludge that chewed the bearings , this is a great idea .
