It is currently Fri Aug 08, 2025 2:17 pm
PostPosted: Sun Jun 24, 2007 11:26 pm
hey.
this mini is making me question happy!!!
so as stated in another post. my mini was cutting out and running bad, and the lights were dimming at night.
thort the generator was cactus, but seems not imo.
it staarted fine the day after all this happened, and again eveything worked.
then a copla days later it needed a jumpstart, but it got going.
now my problem.
it just goes click, the sound tehy make when they wanna crank but battery is flat...
so i tried jumpstarting to no avail.
so i took the battery outa my daily and put that in, and no. still makes 1 click on the turn of the key then nothing. is it possible to miss all the other wiring, and just put a push button on the dash? just battery to button to starter motor??
any suggestions on problems?
thx jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Jun 24, 2007 11:33 pm
entirely possible, but it would be even better to find the intermittant fault. Someone from here will probably help, but I suspect it is a bared wire occasionally touching earth
Noli Illegitimi Carborundum
PostPosted: Sun Jun 24, 2007 11:36 pm
yeah, it is gonna be a khana car, occasional street driver, but definentally want to find the problem.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Jun 25, 2007 7:12 am
Starter motor is seized in my opinion. Try anoher starter motor and see how you go.
Aaron
 Post subject: Starter
PostPosted: Mon Jun 25, 2007 8:12 am
Aaron
Yeah possible....put the car in gear and move it backwards and forwards - that may free up the starter as well.
PostPosted: Mon Jun 25, 2007 8:33 am
Aaron
Seized or burnt out and being a dead short . Just had that trouble with the sports850 and it was frustrating to find , since the spare starter I tried did the same thing :evil:
