It is currently Mon Jul 28, 2025 4:09 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Jun 25, 2007 9:42 pm
Exhaust valves on smallbores can get bent if they hit the top of the block- but that only can happen if valve is bigger than 27mm.
If bore is over stock you can go a little bigger.:wink:
PostPosted: Mon Jun 25, 2007 9:53 pm
yeh thats a good point, but there were no marks on the block or the gasket or anything, still a mystery the bore is certainly big enough
PostPosted: Mon Jun 25, 2007 9:57 pm
sorry to hear that, did you notice anything in particular or just the loss of power?
were you driving her hard?
good to see you got it fixed so quickly :)
PostPosted: Mon Jun 25, 2007 10:01 pm
jut the loss of power down low.
who knows how it happened, and yep all my cars get driven moderately hard, but within their own limits.
PostPosted: Mon Jun 25, 2007 10:11 pm
do you have a picture of the bent valve?
PostPosted: Mon Jun 25, 2007 10:20 pm
Spaceboy wrote:
brickworx wrote:
Spaceboy wrote:
just twist the dizzy back and forth till she goes hard, then tighten the bracket back up..
And when it "blows up" because you over advanced it???
it would stop going hard before you advanced it that much i think.
Which of our Kiwi contingent was it that lent a race engine to someone who advanced it too far by hooking up a vacuum advance and caused it to ventilate the block ...... Simple laws of mechanics , get it running by lining up with #1 at TDC then time with a light , don't F@#$ around by ear unless you REALLY , Really know what you're doing .
PostPosted: Mon Jun 25, 2007 10:22 pm
was only bent by less than a fraction. you couldnt tell with the naked eye, but enough to make it not seat properly.
PostPosted: Mon Jun 25, 2007 10:47 pm
who lends a race engine out?
PostPosted: Tue Jun 26, 2007 10:03 am
Read this one ...
http://www.ausmini.com/forums/viewtopic.php?t=16981
PostPosted: Tue Jun 26, 2007 10:14 am
Good to hear Chris :wink:
PostPosted: Tue Jun 26, 2007 10:45 am
sports850 wrote:
AHHHH
PostPosted: Tue Jun 26, 2007 6:36 pm
ah facts are wrong this is what happens when you run a motor on 91 octane fuel when it was set up to run on 98 minimum.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Tue Jun 26, 2007 6:39 pm
What Mini owner would even think of putting 91 octane fuel into their tank :? :shock:
PostPosted: Wed Jun 27, 2007 3:33 pm
I used to run whatever.
91 or 95, 95 in preference. But 91 a lot of the time. Didn't make a difference to performance or anything, mind you, both my engines are fairly low compression and don't have fancy cams or anything, and we've always used safe ignition timing for these reasons.
Now it's 98 in my car only, and 95 in the clubby as many places (the places I use) only sell 95 or 98, no crappy 91.
