It is currently Mon Jul 28, 2025 3:39 pm
 Post subject: mk1 's' motor question
PostPosted: Mon Jul 02, 2007 10:13 am
Done a few searches on here couldn't find anything so,,Does anyone know the casting number on 1275 mk1 cooper s block?? And what part number would be on the main bearing caps .eg. AEG??? cheers
PostPosted: Mon Jul 02, 2007 11:38 am
Mk 1 "S" block part number AEG312. Main bearing caps - no cast part No. But should have stamped 4 digit number that corresponds to the number stamped on the block (generally on the front of the block next to the water pump).
PostPosted: Mon Jul 02, 2007 11:47 am
Is this still the motor you were asking about before that's an unknown quantity , does it have caps with it ? The caps are matched to the block and other caps will require tunnel boring to match which is an extra expense if not there , something to keep in mind .
PostPosted: Mon Jul 02, 2007 11:51 am
Pretty sure all S blocks Mk1 and 2 have that same casting number on. All or most Mk1s were thin flange though I think.
Thick flange block is more rigid.
No i'm off to have a look at another block on wednesday,,,he reckons its a thick flanged with 9fsay,, which i don't think exists,,,bit of luck it might be a mk2 with mk1 restamp on it, I know a thick flange is about 15mm ,,,How thick would a thin flange be?
PostPosted: Mon Jul 02, 2007 11:53 am
about 6mm give or take. :wink:
PostPosted: Mon Jul 02, 2007 11:56 am
Thanks alot people, very helpful,,now i know what to look for....cheers
PostPosted: Mon Jul 02, 2007 12:01 pm
I just thought i'd add mr vizards book says thin flanged blocks can flex and cause oil leaks, that would have to be a pretty powerfull motor wouldn't it? Does putting the bigger bolts in the thin flange help this...anyone had this problem or is it bit of a myth...
PostPosted: Mon Jul 02, 2007 1:49 pm
I've had a couple of Mk1 S thin flanged road motors, the 1st had standard 1/4" bolts and the 2nd had 5/16". Neither leaked oilz.
I think it matters more on competition motors. :wink:
PostPosted: Mon Jul 02, 2007 4:33 pm
Used thin flanged Mk1 blocks in my J car. Never had any dramas with oil leaks except when a cam follower let go at 8000rpm. Punched holes in front and back of block - oo ah!!!!
PostPosted: Mon Jul 02, 2007 4:50 pm
ouch!! that would of hurt the poor girl pretty bad :cry:
PostPosted: Mon Jul 02, 2007 7:45 pm
AEG 312 is the Mk1 casting number
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
