It is currently Thu Aug 14, 2025 9:33 am
PostPosted: Mon Jul 02, 2007 11:38 pm
hey guys.
i have taken the heater out of the delux, b cos i cooldent get it to work, and it was adding too much weight :P , (giving me the shits actually)
i have a new bottom radiator hose without the heater inlet pipe in it, what is the best way to block the hole in the head l/h side ?
can i get a plate , a bit of gasket, gasket sealent and bam, or is it harder?
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Jul 02, 2007 11:51 pm
thats what my head was like when i bought the car
PostPosted: Tue Jul 03, 2007 6:15 am
Cut the hose off about 2" from the elbow on
the head and stick a bolt in the hose and clamp it down.
Felix
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Tue Jul 03, 2007 7:21 am
ask your parts dealer for 2A180, its the factory blanking plate
see http://www.minimotorsport.de/etk.asp?MO ... f99H%23026
Rover 214 atm ....
PostPosted: Tue Jul 03, 2007 7:43 am
I have a blanking plate you can have.
p.s
Have you had any luck finding the heater vents you indicated you may have stashed in the garage (I am willing to pay for the vents).
btw
I am still located in SA until Sept.
white_mini_man
PostPosted: Tue Jul 03, 2007 9:43 am
p.s
btw
white_mini_man
i totally forgot mate, ill have a look today, im pretty sure i know where they are
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Jul 03, 2007 8:02 pm
I know how to block the heater outlet on the head and it will only cost you 5 cents and a bit of silicone. 8)
PostPosted: Tue Jul 03, 2007 8:35 pm
silicone the 5 cent piece to the head?
thats defacing teh australian currency how dare u even sugest such ludacris actions :P
jks jks
i have the heater vent pics, tehyre uploaing atm.
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Jul 03, 2007 9:07 pm
You are not defacing it. You are puting it to good use. Just fit the 5c between the head and the heater takeoff pipe with a bit of silicone to seal it. (or you could used the outlet as a template to make a plate over the hole)
I would have said to use a 2c piece but you are too young. :lol:
BTW the 2c was great for soldering over holes in radiators and fuel tanks. :wink:
PostPosted: Tue Jul 03, 2007 9:17 pm
i best remember that when i look under seats keep em for holeythings!!!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: No registered users and 263 guests
