thats the plan s meeni,
any chance of getting some more pics on how yours is done,
mainly the seams?
cheers jamie
heres an abstract from transport sa
Tilt Fronts
"Tilt front" is a term used to describe a type of forward pivoting integral engine bonnet, grille and front
mudguard assembly for front engine vehicles. Examples of production vehicles fitted with this type of engine
access are the Jaguar "E" Type and the Triumph Herald.
The fitting of a tilt front will be acceptable to Transport SA providing that:-
a. The new body sections are designed and constructed with no dangerous or sharp projections so that in
the event of an accident the risk of injury to pedestrians and cyclists is minimised.
b. The new body sections do not obstruct the visibility of lamps fitted to the front of the vehicle and in
particular the direction turn signal lamps or headlamps.
Transport SA
September 2003 Modifications to Passenger Cars, Car Type Utilities and Panel Vans Page 19 of 25
c. The new body sections do not obstruct the field of view of the driver. The field of view requirements are
determined as follows;
• With the drivers seat in the rearmost position, it shall be possible to see, unobstructed for the full
width of the vehicle, a line drawn on the roadway 11 metres ahead of the "driver's eye position"
when looking over the bonnet. For the purpose of this requirement the "driver's eye position" shall
lie at the bottom of the of the 95th percentile eye ellipse (reference ADR 15/01 clause 15.1.5.1).
• Alternatively the "driver's eye position" can be taken as a point 750 millimetres above and 270
millimetres forward of the junction of the seat cushion and seat squab with the seat in the lowest
and rearmost position.
d. All lights fitted meet the requirements of Road Traffic (Vehicle Standards) Rules 1999 and ADR 6 or
6/00
e. The anchoring, hinge and latching mechanisms are durable and have sufficient strength to secure the
hinged section. Transport SA may request a submission from a Chartered Professional Engineer if
doubt exists concerning the strength of components.
f. In the case of passenger cars and derivatives manufactured on or after 1st January 1969, an engineering
report presented by a Chartered Professional Engineer would be required, which demonstrates that the
vehicle continues to comply with Australian Design Rule requirements in addition to the above.
