It is currently Tue Aug 05, 2025 6:46 pm
 Post subject: Soft-mount Hydro?
PostPosted: Tue Jul 10, 2007 7:20 pm
Forum Graffiti
Ok so heres the story.. I have a hydro mini and I'm going to be running adjustable coil-overs so I'm ripping the bags out, bla, bla. The subframes are in surprisingly good condition so I'd like to keep them.
What I want to know is is there anyway I can soft-mount the hydro subframe instead of solid-mounting it? I just want a less brutal ride.. still stiff (i mite use some kind of poly bush or something)
Sam
PostPosted: Tue Jul 10, 2007 7:43 pm
If you want a soft ride you should have left the hydro in the car. 8)
PostPosted: Tue Jul 10, 2007 7:45 pm
Forum Graffiti
Haha I just want less vibrations in the car from the subframes..
PostPosted: Tue Jul 10, 2007 7:53 pm
The later Rovers are soft mount, no australian car was.
As such the mounting points for the subframes differ (at least for the front, unsure of the rear). The fron apron panel differs in the front subframe mounts as it must leave a larger gap between the subframe and the panel for the rubber mount.
So maybe you can soft mount it, but it will take some modification.
Poms like to convert their soft mounted subframes back to solid.
PostPosted: Tue Jul 10, 2007 8:02 pm
Forum Graffiti
Well thats interesting.. I wasnt sure whether the dry subs were soft mounted or not. There must be a reason why they revert them back so I think I'll just keep them solid mounted then, less work for me! :P
Thanks guys
PostPosted: Tue Jul 10, 2007 8:16 pm
I haven't managed to read through the marketing hype, but people reckon that the subframes shift a little under extreme cornering and this leads to a little vagueness. But I'm sure I've also read that it's pretty minor. I don't know if it's the need to buy stuff to make you go faster (even if it doesn't) or if it's just leads to a real difference.
I'd love to hear some input from the Rover driving ranks on this before moving on, any more feedback out there?
Replacing the subframe rubbers with new rubber (not urathane) inserts will go a long way, also look at the engine steadies, it was pretty common to replace these with urathane inserts. these transmit a lot of vibration and road noise to the cabin. There's always earplugs and a bigger radio however....
PostPosted: Tue Jul 10, 2007 8:19 pm
Forum Graffiti
radio.. what radio, I have a weber! :P
PostPosted: Tue Jul 10, 2007 8:29 pm
Ahh, heavy metal is your game then. How can you hear anything else?
PostPosted: Tue Jul 10, 2007 8:34 pm
Forum Graffiti
Induction noise good... rattles bad. I hate rattles, my last one was a chronic ratla :evil:
PostPosted: Tue Jul 10, 2007 9:02 pm
The Pommy rubber mounted subbys are so sloppy, they move in the body when you turn the wheels to and for.
No wonder they convert them back... :lol:
The coilovers usually mount on the top shock mounts which (surprise, surprise..) are on the BODY, not the subby.
So, methinks you will have noise transmission probs anyway, rubber subby or not. :wink:
PostPosted: Tue Jul 10, 2007 9:05 pm
Forum Graffiti
Good point.. its suddenly not looking like such a good idea, or even worth it for that matter... :?
PostPosted: Tue Jul 10, 2007 9:12 pm
soft mounting of the subbies allowed for the worn out panelling machines (forty years old) used to make the body. That is the tolerances that used to be + or - 1 milimetre grew to + or - 2.5 milimetres for example.
anyway why ruin the greatest assett of a Mini and kill the handling? By a Hyundi Excel.
PostPosted: Tue Jul 10, 2007 9:18 pm
Forum Graffiti
Haha, well thats my other car...
It was an idea... :P
Not such a good one now tho is it! :roll:
If you want rubber mounted frames, just put a rover front one in...
but yes they do move around.
but if its a daily driver the nicer drive makes it ok.
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Tue Jul 10, 2007 9:21 pm
Forum Graffiti
Ooo that reminds me, I'll be needing to get another front half of a roundie for my removable front from Brickworx too... although I think postage is going to be a biatch :evil:
Users browsing this forum: No registered users and 112 guests
