It is currently Thu Aug 07, 2025 3:47 am
 Post subject: Zeroing the odometer
PostPosted: Tue Jul 10, 2007 1:38 pm
When I was making enquiries about having the speedo recalibrated I was asked the question "Do you want the odometer reset to zero at the same time?"
Resetting must be different to "winding back" an odometer which I understood to be illegal.
As my motor and most of the car will be rebuilt by the time it is finished having a zero odometer would fit with a "new" car.
Looking at the cost of recalibation and reset I may as well spend about $50 more a buy a new one from Mini Spares but in case I don't does anyone know if resetting the odometer is 'doable' to the home based tinkerer?
David L
PostPosted: Tue Jul 10, 2007 1:43 pm
Dave, I sent my speedo forward to 00000 using a speedo cable and a reversable drill.
PostPosted: Tue Jul 10, 2007 3:06 pm
If the speedo is from a roundie just take off the glass and then push sidewards and move the numbers with your fingers.. not that of course I have done this, just heard it from a friend of a friends friend :P
PostPosted: Tue Jul 10, 2007 3:09 pm
My hat off to your patience. I disassembled the odometer and zeroed it manually. It's quicker, provided you don't break it!
PostPosted: Tue Jul 10, 2007 3:16 pm
"If the speedo is from a roundie just take off the glass and then push sidewards and move the numbers with your fingers.. not that of course I have done this, just heard it from a friend of a friends friend"
nuh can't be done. the tabs on the number reels will all be crooked, so when you start to do some miles it looks shithouse.
PostPosted: Tue Jul 10, 2007 3:18 pm
Yeah, when my old one died, the guys said it was cheaper to buy a re-conded one than fix the old one, and it was zeroed when I got it. Great, '65 mini, with 9000miles on the clock :D
It's been 19Yrs in the Making.....Last Rego sticker 6/89
But SOON, VERY SOON
PostPosted: Tue Jul 10, 2007 4:14 pm
Havent done it to Mini's but have done it to Sigma's (shudder) and Honda's. Used to use a small flat blade to push the number sideways where it can be moved by hand. As mentioned you need to line them up carefully though.
We used to do it when we replaced the speedo under Warranty, had to set it to what the reading on the original one was.
PostPosted: Tue Jul 10, 2007 6:11 pm
The one that I have at home says otherwise..... :roll:
 Post subject: Sick Bird
PostPosted: Tue Jul 10, 2007 6:57 pm
You do all know that this is illegal :roll:
 Post subject: Re: Sick Bird
PostPosted: Tue Jul 10, 2007 6:59 pm
Thats what i thought.
Steve
Classic Not Plastic
PostPosted: Tue Jul 10, 2007 7:04 pm
Steve
That is why I mentioned it my original post - as I was offered to have the odometer 'zeroed' by the reputable speedo rebuilder and calibrator.
Is there a technical difference between zero and 'wound back' a few thousand clicks to make it look good. :?
David L
PostPosted: Tue Jul 10, 2007 7:22 pm
Wombat wrote:
Steve
NO....not a sausage of a difference....tampering with an odometer is still illegal.
PostPosted: Tue Jul 10, 2007 7:53 pm
So when i replaced my speedo/odometer with a new one that actually worked but didn't read the same number it was illegal :? hmmm, i know what i'd prefer!
Anyhow, a 5 digit odometer.... how many times can that go round the clock, pfft. Seriously, on a car of my minis age, who knows whats original. Maybe the panels....
Carl
PostPosted: Tue Jul 10, 2007 8:32 pm
Well they'll all make zero eventually anyway and then go back around again, most minis won't be far off this anyway. So these days it might be pretty explainable.
PostPosted: Tue Jul 10, 2007 9:40 pm
if you are lucky!!!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: Bing [Bot] and 81 guests
