It is currently Fri Jul 18, 2025 4:59 pm
 Post subject: Drum Brake adjustment
PostPosted: Mon Dec 20, 2004 1:37 pm
My handbrake isn't holding so I went to adjust it only to find it's already maxed out. I backed it off to adjust the rear drums then jacked her up and pulled off the wheel but it looks like a special tool is needed. Anyone have any idea on the tool needed or photo's of one? I rang around all the auto shops up here and noone knows what I'm talking about :roll: Help :!: :?
PostPosted: Mon Dec 20, 2004 1:46 pm
We used this really small spanner....
PostPosted: Mon Dec 20, 2004 1:48 pm
You shouldn't need any special tool to adjust the rear brakes and hand brake.
I'm pretty sure the sequence is:
Adjust the pedal brake first with the handbrake disengaged. You should adjust them so that you can hear the shoe lightly rubbing against the drum (I generally go further than 'lightly rubbing' because I end up with the pedal on the floor if I have the shoe too far off the drum).
Apply the hand brake to two 'clicks' & adjust the nuts at the lever so that the wheel doesn't spin with you try to force the wheel (actually put the wheel on to test this).
dewey
P.S :: Adjusting brakes (especially twin-leading shoe drums) is up pretty high on my shit-me-off-o-meter.
dwightgunning.com
PostPosted: Mon Dec 20, 2004 1:59 pm
Stupid me should have taken a photo while I had it apart :lol: The adjusting nut (for lack of a better term) on the drums looks like it's locked in place be a piece of spring loaded metal on either side, looking like it requires a tool that would force the locking plates open then slide past and onto the adjusting nut . If you can make sense of my description you're doing well :lol:
PostPosted: Mon Dec 20, 2004 2:08 pm
The square adjusting nut is on the back of the backing plate....not the "shoe side" ......carefully make sure it is free before swinging off it as they do get rusted up and you can round the adjuster off (Mini people should buy the WD-40 company).
AFAIR the adjusters all go the same way on each wheel.....I usuall give the pedal a few pumps afterthe adjustment to "centre the shoes....
PostPosted: Mon Dec 20, 2004 2:21 pm
Just call me Homer Doh! :lol: The last set of drum brakes I looked at had the adjuster on the shoe side :roll: Is it clockwise to move the shoes out or counterclockwise?
PostPosted: Mon Dec 20, 2004 2:28 pm
Clockwise looking at it moves the shoes out.
If the adjuster goes nearly right in and still no good, the shoes need replacing.
PostPosted: Mon Dec 20, 2004 2:41 pm
Thanks Doc, the shoes are fine, barely worn in fact. I'd say they were never adjusted correctly in the first place.
All done and working better than when I got it, handbrake now holds on a 45* incline 8)
Users browsing this forum: misty-mk1 and 107 guests
