Wolfman wrote:
Stupid me should have taken a photo while I had it apart
The adjusting nut (for lack of a better term) on the drums looks like it's locked in place be a piece of spring loaded metal on either side, looking like it requires a tool that would force the locking plates open then slide past and onto the adjusting nut . If you can make sense of my description you're doing well
The square adjusting nut is on the back of the backing plate....not the "shoe side" ......carefully make sure it is free before swinging off it as they do get rusted up and you can round the adjuster off (Mini people should buy the WD-40 company).
AFAIR the adjusters all go the same way on each wheel.....I usuall give the pedal a few pumps afterthe adjustment to "centre the shoes....
