It is currently Tue Aug 12, 2025 1:13 pm
 Post subject: oil capacity?
PostPosted: Wed Jul 11, 2007 2:00 pm
ive done a search, cant find it. but i know it MUST be on here somehwere.
whats the oil capacity for a 998 A=? its 4 litres yes?
i should know this by now... :oops:
78 Leyland Mini - Prince
PostPosted: Wed Jul 11, 2007 2:09 pm
yup... 4.... 5 with an oil cooler..
PostPosted: Wed Jul 11, 2007 2:21 pm
I thought it was 5 with oil filter?
I usually put 5 in! :lol:
PostPosted: Wed Jul 11, 2007 2:26 pm
I usually have a little left over from 5 litres when I change a filter as well as oil.
PostPosted: Wed Jul 11, 2007 2:28 pm
ok cool cheers guys. i've got a 6L bottle, so i'll leave about 1.5-2 L
PostPosted: Wed Jul 11, 2007 2:33 pm
KMX? 8)
PostPosted: Wed Jul 11, 2007 2:34 pm
you know it :d
PostPosted: Wed Jul 11, 2007 4:41 pm
Actually, it's 8.5 Imperial pints, but in todays currency, that's 4.83 litres.
So, if you leave a litre and a 'bit' in the bottle , you'll be right Dylan.
Ah yes, that includes the filter :P
Hooroo
Rod Image
PostPosted: Wed Jul 11, 2007 5:57 pm
got just under 2 L left, the mark is a smidge under "max" on the dipstick :D
PostPosted: Thu Jul 12, 2007 6:07 am
Wait until it drains down, or even spin the starter a couple times. It takes a while to drain down through the head and block. Either that, or you didn't drain it all out. Mini sump is a shocking design for geting it all.
PostPosted: Thu Jul 12, 2007 12:31 pm
dont you worry about that young grasshopper! :D i warmed ujp the oil and let it drain for aaaaaaaaaaggeeeeesssss, with the passenger side lifted up a bit for a while.
then, i put about 4L of oil in, so should be all cool :wink:
but thank you anyway :D
PostPosted: Thu Jul 12, 2007 12:34 pm
Well then you should be a bout 800ml short :roll:
Users browsing this forum: Barkfast and 231 guests
