It is currently Thu Aug 21, 2025 9:48 pm
PostPosted: Wed Jul 18, 2007 7:51 am
I'm pretty sure it's OK but want to confirm that the newer plastic type clutch master cylinders are interchangeable (without any mods) with the old tin type. I've done a search but haven't found the answer yet. Thanks.
Ziff
 Post subject: Master cylinder
PostPosted: Wed Jul 18, 2007 9:49 am
Fitted hundreds of the plastic ones with no problems (unless people fit the brake master around the wrong way)....lol :lol:
Regards,
Andrew
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Wed Jul 18, 2007 12:52 pm
Yeah are fine.
Only problem I found was the plastic extension tubes that I had before on my clutch didn't seal again. But since it's clutch, and you can now see through them to view the fluid level it's all ok.
I would care bout the brake but I got a brand new Cooper S tin (taller than standard mini) type one for $120, I think that was cheap.
PostPosted: Wed Jul 18, 2007 4:14 pm
Great. Thanks very much fella's.
Ziff
Users browsing this forum: No registered users and 203 guests
