It is currently Wed Aug 20, 2025 1:34 pm
PostPosted: Sun Jul 29, 2007 10:25 am
Resident Test Pilot
Morris has picked up a nasty smoking habit. Blue smoke = oil I guess. He is also missing/starving when going round right hand bends.
This is sounding very sinister to me ?
Any thoughts. Something broken inside ???
PostPosted: Sun Jul 29, 2007 10:56 am
Noooooooooooooooooooooooooooooooooooooooooooooooooooooooo! :shock:
PostPosted: Sun Jul 29, 2007 11:05 am
Does it have a servo? (Booster) How are the brakes? :roll: :?:
Sir Alec! we are not worthy!
PostPosted: Sun Jul 29, 2007 11:34 am
Resident Test Pilot
no servo.
PostPosted: Sun Jul 29, 2007 11:50 am
Thought it might be brake fluid leaking into the servo and getting burned via the vacuum hose.
I would take the top of the carby float bowl and clean it out, check float (any fluid in it?) and float height, and water in fuel / float bowl bottom?
Check fuel pump output, measure flow rate into a jug?
Also do normal checks on compression, points gap, plugs etc? :shock:
:P
PostPosted: Sun Jul 29, 2007 11:52 am
I is a mookenik
didnt u juz put a new cam in the engine matt? blue smoke sounds odd but the missing around corners sounds like not enough fuel... happen to me when i put the new carby on for a while till i realised that the old carby had been modified with a bigger needle and jet so compensate with the cam? possible problem.. when u say he blows blue smoke how often?
 Post subject: Something obvious...
PostPosted: Sun Jul 29, 2007 11:53 am
What Graham was saying was look for obvious things.....the vac line to boosted cars is a common one....a vacuum/breather line off, split or blocked is another possibility.
You could also have two unrelated problems :!: check the fuel lines from the carbys right back to the tank(s)...I suppose you could also have a fuel pump thats on the way out...next :lol:
PostPosted: Sun Jul 29, 2007 11:55 am
When you swapped the heads did you scrape ALL the carbon off the pistons? If you did, it may be the cause of the oil smoke- the carbon on the edge of the piston crown can act as a seal against oil burning once motor has a few miles up.
If so, it will come good once it carbons up a bit.
It could also be the valve guides letting oil get sucked down if worn- I always put valve stem seals on the inlets now, even on old smallbore heads that never had proper ones originally.
 Post subject: Head change...
PostPosted: Sun Jul 29, 2007 12:04 pm
It could also be the valve guides letting oil get sucked down if worn - I always put valve stem seals on the inlets now, even on old smallbore heads that never had proper ones originally.
Always nice to have the full story...aye Doc :!:
Maybe Ausmini should get a change of format so that all the problems with a particular car/engine are in the one place :roll: :lol:
PostPosted: Sun Jul 29, 2007 1:58 pm
Resident Test Pilot
it has driven quite a lot of miles since the head change and started doing this today. thought it might have been internal and drastic to come on so suddenly.
PostPosted: Sun Jul 29, 2007 2:48 pm
The Forkmeister
God dam!!, when will it end.... :( , i hope it's nothing too serious Matt.
May the fork be with you.
 Post subject: Re: Head change...
PostPosted: Sun Jul 29, 2007 5:00 pm
Then what would we talk about?
PostPosted: Sun Jul 29, 2007 5:30 pm
I is a mookenik
I KNOW!!!
spider pig..spider pig does whatever spider pig.. can he swing through a web..no he can't cause he's spider pig :D sorry i juz watched the simpsons movie and still excited about it
PostPosted: Sun Jul 29, 2007 7:30 pm
tinymorris1969 wrote:
I KNOW!!!
Righhhhhhhhhhhhhhhhhhttttttttttttttttttttttttttt :? Come here Tiny and let me slap you! :wink:
Users browsing this forum: No registered users and 228 guests
