It is currently Sat Jul 19, 2025 12:40 pm
 Post subject: Santa Pimped my Ride
PostPosted: Sat Dec 25, 2004 5:52 pm
I'm one very happy camper.
The second I put the wheels on and stood back, the best kept secret in mini ownership hit me "CLUBBIES ARE THE BEST LOOKING MINIS".
After I had the camber and castor set up the hadling improved out of site. And if you think a mini handles the corners well, ya gotta drive one with a LSD :twisted: worth the little but of extra work required to keep her going in a straight line.
All thst is left now is the roll cage.
http://www.shoalhaven.net.au/~nubtwo/mm ... arm054.jpg
http://www.shoalhaven.net.au/~nubtwo/mm ... arm055.jpg
http://www.shoalhaven.net.au/~nubtwo/mm ... arm056.jpg
http://www.shoalhaven.net.au/~nubtwo/mm ... arm057.jpg
http://www.shoalhaven.net.au/~nubtwo/mm ... arm058.jpg
http://www.shoalhaven.net.au/~nubtwo/mm ... arm059.jpg
http://www.shoalhaven.net.au/~nubtwo/mm ... arm060.jpg
http://www.shoalhaven.net.au/~nubtwo/mm ... arm061.jpg
PostPosted: Sat Dec 25, 2004 6:15 pm
that looks hot oz, you really did a great job on the old clubby.
I see the wheels and tyres are on now, really looks alot smarter now. you have a tow hook sticker on the front, where about is the tow hook attached too?
cant wait to see it on the 2nd.
1974 Moke - 998cc
PostPosted: Sat Dec 25, 2004 6:33 pm
There is a plate bolted to the subfrae just behind the licnce plate and we welded a loop to it.
At the last minute I said "lets put pins in the rear corners and get rid of the bonnet hinges, it was a pain in the ass of a job but worth it as it os a little raised at the back now. THe extra radiator means the temp does not go over 1/4 and we even found a few strange things to fix while we were at it.
A small problem with the fan rubbing if the radiator shroud under load should not be too hard to fix and I even got rid of the play in the steering which is now tight as.
Cant wait for the 2nd to take her for a really good long run.
PostPosted: Sat Dec 25, 2004 8:48 pm
Oz.... looking very very toight............. can't wait to see some vids of it on the track :P :P :P
I got nuthin......................
PostPosted: Sat Dec 25, 2004 8:56 pm
phat ride Chris.... 8) lookin good!
PostPosted: Sat Dec 25, 2004 10:09 pm
Great stuff! Engine envy all over my face! (plus I want your new wheels)
PostPosted: Sun Dec 26, 2004 8:23 am
Thanks Guys
A bif thanks must go to Dr Mini who was nice enough to take a call from me Christams eve while he was preparing the family's Christmas diner and stil managed to help me out.
Just before I picked the car up Christmas eve Garry re tensioned the head. Unfortunatly the dodgy chrome rocker cover does not allow the gasket to sea properly and by the time I got home oil was piising out the front and back of the rocker. However with Kev's experience he new exactly how to fix it and Christmas morning I had the tool and it it was fixed in no time.
PostPosted: Sun Dec 26, 2004 10:59 am
Lookin good chris!
[Maverick] 1971 Mini K
PostPosted: Sun Dec 26, 2004 11:03 am
And is it going any better now with the shorter diff (3.76) and a coupla mm off the head? :P
PostPosted: Sun Dec 26, 2004 12:18 pm
Yep, and your car just proves that point, looks great :D
PostPosted: Sun Dec 26, 2004 12:49 pm
yeah the wheels make all the difference, it just proves my opinion that 12 inch wheels are the best looking.
PostPosted: Sun Dec 26, 2004 3:30 pm
Nice Job and looking forward to have a good bopeep on the 2nd :shock: 8)
What camber and toe in did you set it at for the front and back and have you adjusted for the road or track :?:
Hope you all had a Loverly Christmas Day
PostPosted: Sun Dec 26, 2004 6:18 pm
Gafmo
They ran out of time of Christams eve to et the castor and camber properly. It had 7 deg castor which is OK for the tack I suppose but I bit too much for the road it was making teh steering too heavy. In the end we settled on 3 deg neg camber, 4 deg castor and 1/16 of an inch toe out. Left back as is.
PostPosted: Mon Dec 27, 2004 1:16 am
Castor... didn't know ya could adjust them or buy something that allows for adjustment for Mini's??
PostPosted: Mon Dec 27, 2004 5:22 am
For the rear you can get Caster Brackets which is a nut and bolt method which changes the angle of the Swivel Pin by Mini Spares or KAD, one also have Tie Inn/Out
For the front Adjustable Bottom Arms and also adjustable Tie Rods.
No forgetting if you lower the car in hight you change the camber also.
Users browsing this forum: No registered users and 70 guests
