It is currently Fri Jul 18, 2025 5:48 pm
PostPosted: Mon Dec 27, 2004 5:28 am
Whoever did the front end on this car made up a tricky rose joint front end. Only prblem is you cant adjust the camber unles the romove the bottom arm, turn it in or out a few times, replace it and them measure the camber again, pretty time consuming. Mad Matt made me an excellent set for my last mini taht you could adjust as in minutes.
PostPosted: Mon Dec 27, 2004 5:32 am
Yer I purchased Heavey Duty Rose Joint front bottom Arms and I figures you would have to disconect it from the ball joint tp adjust..bugger :?
PostPosted: Mon Dec 27, 2004 5:46 am
at least its not the sort of things you need to adjust everyday
PostPosted: Mon Dec 27, 2004 6:14 am
Oz,
You should only have to loosen the locknut, take the inner pin out then pull the arm and hub far enough to spin the rose joint. As long as the threads are not rusted up or full of crud.. :lol:
Users browsing this forum: No registered users and 116 guests
