It is currently Tue Aug 12, 2025 9:07 pm
 Post subject: Bearing secrets
PostPosted: Sat Sep 08, 2007 2:59 pm
I am replacing the front bearings on my drum braked Moke tomorrow
Any tips and tricks I should be prearmed with?
PostPosted: Mon Sep 10, 2007 11:10 am
Remove split pins and loosen big hub nut before you jack it up!
Check for wear in the hub and the stub (drive flange) If the bearings have been driven on for too long while rooted, the hubs and flanges will wear, particularly flange stubs when bearing inner spins.
Your new bearings will have play, but not from the bearings, but rather the wear on the hubs / flange stubs.
Oh and always fit new seals :P
Sir Alec! we are not worthy!
Users browsing this forum: No registered users and 183 guests
