It is currently Sat Jul 19, 2025 5:59 am
 Post subject: MK 1 S Trim
PostPosted: Fri Sep 14, 2007 11:53 am
Anyone got a pic of original Mk 1 Cooper S seats and door cards? I am trying to work out what pattern the stitching was.
Ta.
PostPosted: Fri Sep 14, 2007 12:54 pm
Hi GT,
British or Oz assembled? I can help with British.
Regards
Al
PostPosted: Fri Sep 14, 2007 1:30 pm
yea OZ Mk 1 S.
Sorry, should have said.
PostPosted: Fri Sep 14, 2007 2:04 pm
Early Mk1 S seats were same as Mini Deluxe, not sure about the door cards.
PostPosted: Fri Sep 14, 2007 3:01 pm
I believe seven stripes as well, no different.
PostPosted: Fri Sep 14, 2007 3:19 pm
like this?
or like this?
or like this?
PostPosted: Fri Sep 14, 2007 3:26 pm
If the style was the same as the Deluxe, my car is a Nov 65 Deluxe - it has seats like the second picture, and door cards and rear cards like the (EDIT) the picture of the grey vinyl below.(EDIT).
PostPosted: Fri Sep 14, 2007 7:02 pm
Last of the Mk1s had seats like your 1st pic, I had a 68 Mk1.
PostPosted: Fri Sep 14, 2007 7:23 pm
The first pic that you have posted is Mk2 Cooper S and Mini K , the second is early Mk1 Cooper S and Deluxe , which changed to pattern shown below , in 1966 sometime ( the 3rd pic you posted looks correct)
MK 1 FRONT SEAT 1966-1969
MK1 REAR SEAT 1966-1969
MK1 DOOR CARD 1966-1969
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Fri Sep 14, 2007 7:31 pm
thank you.
I was confused between Mk 2 / Mini K trim and Mk 1 / Deluxe trim.
They are kinda similar to a square person.
PostPosted: Fri Sep 14, 2007 7:36 pm
Some very late Mk1's can be found with Mk2 trim and other Mk2 parts , unofficially called Mk1 and a half by some people I believe
1965 Morris 850
1977 Leyland LS
PostPosted: Fri Sep 14, 2007 7:40 pm
We had a April 65 deluxe, same seats and colour as in your second pic. Door cards and rear cards were a little different. Just went downstairs and dragged them out, sorry about their grubbiness.
The ones marked are from our car and the other rear card ( the only one I have ) is also from a 65 deluxe.
 Post subject: mk1 carpet seat
PostPosted: Thu Sep 27, 2007 11:57 am
Does anyone know if it is possible to source the mk1 cooper s carpet ?
I think it was called "westminster" and apparently it was made of goats hair ?
Was mk 2 carpet special or wasw it just a basic loop pile ?
Also , anyone know of motor trimmers to make carpet set for mini and upholster seats to mk2 specification ?. I am located in Sydney.
 Post subject: Re: mk1 carpet seat
PostPosted: Thu Sep 27, 2007 12:00 pm
I borrowed a template set from our good friend 'Mick', and had my trimmer in Syd make a loop pile carpet set for my GT.
The pattern templates are correct for GT, and Mk 2 S. Maybe Mk 1 S too.... not 100% sure.
My trimmer made copies of the templates. He's in NW Sydney. Can PM address if you want a trimmer in that area.
PostPosted: Thu Sep 27, 2007 12:09 pm
Depends which year Mk1 you are talking about . The following info is from another post of mine :
According to Rover Australia , Cooper S cars from start of production in August 1965 thru to November 1965 had a loop pile carpet , sourced from New Zealand . From December 1965 thru to late 1968 , they had a ribbed Westminster style carpet , which was made in Australia . From late 1968 thru to end of production in July 1971 , the cars had a loop pile carpet , again sourced from New Zealand..........Mk1 carpets came in a variety of colours to match the trim and paint . Mk2 carpets were mostly black which had a tendency to fade to a dark green colour over time .................All Cooper S carpets were made to the same pattern
The Westminster type is available from The Gibbon Group in Qld , and is called Tretford , tel number 07 38811777 . Its quite expensive at $75 / Metre plus GST plus baling fee $29.50 plus delivery fee ... You will need 4-5 metres
Cheers ............
1965 Morris 850
1977 Leyland LS
