It is currently Sun Aug 17, 2025 5:55 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Sep 17, 2007 1:08 pm
i remember my 1100 clubman engine being blue back in the day
PostPosted: Mon Sep 17, 2007 1:09 pm
Somebody once told me that a black engine would radiate heat more efficiently and keep cooler. Is this complete crap or is there something to it?
Maybe the reverse is true and the black will run hotter.
PostPosted: Mon Sep 17, 2007 1:12 pm
'tis why radiators are black :wink:
PostPosted: Mon Sep 17, 2007 1:55 pm
ClubmanGT wrote:
czerial wrote:
bubba, yours should of been that greeeny colour.
And the 1100 motors were deffinately blue.
Chris,
Just to throw a spanner in the Leyland Aus works, my 1098 Clubbie has a green motor - and it's original!
Gavin
GREEN !?!?!?
never heared of that (not saying i dont believe you, just shoclked!)
PostPosted: Mon Sep 17, 2007 3:07 pm
My original BMC 850 '63 motor is blue - no sign of any green anywhere :?
David L
PostPosted: Mon Sep 17, 2007 4:05 pm
Maybe BMC had an employee who was colour blind? :)
PostPosted: Mon Sep 17, 2007 6:54 pm
My 74 clubby van is a blue 1098cc, I have a 1990 1275 Jap motor in red. I strongly belive these colours to be orgional.
I've wondered this as well, (were the engines colour coded for 'cc' or models) I thought they may be like the holden motors black, blue, red etc :?
PostPosted: Mon Sep 17, 2007 7:05 pm
I think that 850's were dark 'castrol' green, deluxe ,cooper s, 1100 ,GT , and early clubman with remote shift were the lighter green. clubman 1100 with rod change were blue as Chris said, 998 clubman were black 1275 LS were also black. the gold colour does ring a bell but I don't remember seeing too many of them. 850's were dark green because they come from England and had their engine number riveted to the engine in the normal place and removed in Australia the plate was then tied to the engine with a peice of string!
PostPosted: Mon Sep 17, 2007 7:18 pm
Online
Mini-K was gold, so was the Oz Morris 1100.
Same motor, but M1100 was only 3 synchro box not 4.
Last edited by drmini in aust on Mon Sep 17, 2007 7:19 pm, edited 1 time in total.
PostPosted: Mon Sep 17, 2007 7:19 pm
From the Mini kingdom catalogue...
Cooper S = Metallic Green
Mini 850, Cooper = Dark Green
Mini Deluxe and Mini-K = Metallic Beige
From the top of my head....
As above plus
Morris 1100 = Metallic Beige
Mini Clubman = Blue
Clubman GT looks like Metallic Beige (in the only colour photo that I have)
Leyland Mini (Late) = Black
Later UK engines are red.
PostPosted: Mon Sep 17, 2007 7:24 pm
I've had a Deluxe which was the Metallic Beige as well as a K box in that colour.I've also had a clubby 1100 block in blue.
PostPosted: Mon Sep 17, 2007 9:29 pm
Gt motor has no mechanical fuel pump (memory)
Is definitely a 1275 motor (had 12g940 head), there are no pockets to accompany smaller head. and is 1200 prefix block.
Is it possible that it was sprayed wrong colour at factory,
"last block on a friday and couldnt be botherd to change paint" or similar ?????????????????????????
i havnt found any green and it is definitely bue - dark blue sorta navy type colour
wouldnt be the first bodgy thing leyland did
ill have to measure the bore to see if it has been out before, and if it is larger i can say its been done by somebody after.
Brenton
PostPosted: Mon Sep 17, 2007 9:40 pm
The Cooper S motors were fully imported and came painted the English Green. They were then re-sprayed to the local Metallic Green. You can see on the motor where it was repainted.
I don't know what they did with the Clubman GT but they were also a fully imported motor and could have had similar treatment.
I have a colour photo of a brand new Clubman GT (1971) when it was being road tested by Modern Motor magazine and it looks like Metallic Beige.
BUT!!!! Leyland changed things a fair bit in the days leading up to the P76 and they changed the engine colours to blue on most cars that they built during that period (72 to 74)
PostPosted: Mon Sep 17, 2007 9:44 pm
Does your blue look like the bits of blue on this motor?
http://www.ausmini.com/forums/viewtopic.php?p=441477#441477
PostPosted: Mon Sep 17, 2007 9:45 pm
yeah its a 11/72 so thats what i want to believe :D
Users browsing this forum: drmini in aust and 362 guests
