It is currently Mon Aug 11, 2025 10:58 pm
PostPosted: Wed Oct 10, 2007 7:55 pm
hi, i'm woundering how to seal the shafts. i know that hiff have special seals but i carn't get any info on hs4 1"1/2 carbys. machine a grove in the shaft each side and putting in a rubber o-ring or a special o-ring for the friction. will this work.
PostPosted: Wed Oct 10, 2007 10:27 pm
You will constantly be changing the seals.
not a very good carby for sealing boost in
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Wed Oct 10, 2007 10:34 pm
Put weber bearings on throttle shafts,stops air leaks and shafts will never wear again...P.M me if you want to see pics of some installed..
PostPosted: Wed Oct 10, 2007 10:37 pm
aren't they too big for an SU?
PostPosted: Wed Oct 10, 2007 10:44 pm
Mines got bearings on them and its a old trick that used to be done years ago,not sure on size, but they fit with a bit of machining on carb body.
PostPosted: Wed Oct 10, 2007 10:49 pm
On as HS type the body is very thin...
i have seen it done but i thought weber bearings were too big
PostPosted: Wed Oct 10, 2007 10:51 pm
This space for rent
What you probably need is this:
http://www.ausmini.com/forums/viewtopic.php?t=35277
PostPosted: Wed Oct 10, 2007 11:16 pm
[img][img]http://i152.photobucket.com/albums/s193/suffolk_photos/su002.jpg[/img]
This is on a twin setup and has 2 bearings each side of throttle shafts..cheers[/img]
PostPosted: Thu Oct 11, 2007 9:52 pm
Very nice... 8)
Users browsing this forum: No registered users and 280 guests
