It is currently Tue Jul 22, 2025 7:13 am
 Post subject: what does it mean when?
PostPosted: Sat Oct 13, 2007 3:43 pm
You turn off your car but it turns over once more after the key has been turned off? What do I need to adjust?
PostPosted: Sat Oct 13, 2007 3:46 pm
I want to have Al's babies
It's called run on. Has something to do with the carby being too lean or rich, i believe.
PostPosted: Sat Oct 13, 2007 3:56 pm
or your engine being coked up
Run-on , pre-ignition several other names , basically it means for some reason the fuel/air mix is igniting under pressure in the engine even without the plug sparking . Has it always done it or only just started lately ?
PostPosted: Sat Oct 13, 2007 4:00 pm
have been playing with the twin carb tuning, so is that the likely cause :?
PostPosted: Sat Oct 13, 2007 4:01 pm
If mooman doesn't mind me jumping in, the BOC's always done this on and off (i posted about it just after i joined) and it hasn't chanhged.
It's usually a sign that my oil's a little low.
PostPosted: Sat Oct 13, 2007 4:26 pm
This space for rent
My car used to run on all the time until it was properly tuned. It's often a combination of things:
* Too rich mixture
* .. left for too long, causing excessive carbon buildup in the combustion chambers. This glows and stays hot and ignites the air/fuel mixture after the ignition is switched off.
* Timing too far advanced, causing higher than normal engine temperatures.
* Compression ratio too high for the octane fuel you're using, allowing the fuel to detonate under compression (like a diesel).
Run-on is a sign of bad things going on in your engine and you need to do something about that. In the interim, I always used to control the run-on using the clutch in gear -- not good, but better than letting the engine fire uncontrollably and potentially blowing a hole in a piston/valve.
Users browsing this forum: Bing [Bot] and 86 guests
