It is currently Sat Jul 19, 2025 4:37 pm
 Post subject: all is not at it seems
PostPosted: Thu Oct 18, 2007 10:44 pm
well after driving my little buz box to work 4 days in a row, on the 5th day it decided that 5 days was one day too many and it up and stopped.
so a call to James at minis of sydney and he takes it away to conduct an autopsy.
a carefull examination
apparently I had exhausted my fuel supply by way of a leaky fuel tank.
a fuel gauge that indicated a 50% fuel load didnt help.
the autopsy revelead a few other problems, time for an overhaul and other repairs
rebuild/replace gearbox
new clutch kit.
machined flywheel and drive plate.
cylinder head work.
camshaft upgrade
all bearings,rings.
oil pump.
steering rack repair.
headlight dipper switch move.
tyres.
extractors and exhaust
wiper upgrade .
plus a bit of metal cancer, full respray may be coming
oh yeah
fuel tank and gauge
James is going to be busy
PostPosted: Thu Oct 18, 2007 10:51 pm
Do you know this James Well. I can't see how he can say there are problems with half these things without pulling apart
PostPosted: Thu Oct 18, 2007 10:53 pm
extractors ? whats the problem with original exhaust?
PostPosted: Thu Oct 18, 2007 11:10 pm
yikes, so a full restoration then
PostPosted: Thu Oct 18, 2007 11:15 pm
ok a bit more explaining
some of this is elective surgery.
I was considering a front cut upgrade/conversion (and someone to do it for me) we discussed a few things to do while he has my car I asked him to put together an alternate cost effective solution for a bit of extra grunt without going over the top as well as interior cosmetic things.
so some work is required, some work asked for and was on the cards before my fuel tank/guage problem, this just hastened it
PostPosted: Thu Oct 18, 2007 11:17 pm
Erm....top it up with fuel and keep going...
unless you want to do a full resto on it :?
Sounds like a lot of wasted money there...not saying it wont all do good, but if it got you to work 4 days in a row and the only thing that stopped you was fuel..then fill it up and keep driving until you need to do work on it.
If you got the money go for it, but dont think you have to do even half the things on that list.
PostPosted: Thu Oct 18, 2007 11:27 pm
I'd have to say then...if the Box has problems then do it.
but other wise unless its a 1275 and you have disc's I'd search for those and do it to that instead
my 2c
its looking that way.
I had intentions of doing some of this, well getting somebody to do it that is, over a period of time anyway.
but i may as well get as much done as a I can now.
the re spray was a wish list for later but I am sure as soon as we start to clean up the rust we can see then there will be more we didnt see
PostPosted: Fri Oct 19, 2007 12:07 am
sounds like fun :)
get him to replace the pistons and give it a fresh rebore - just replacing the rings never works out for the best, and it's not much extra in terms of parts - while it's all apart, get it done properly
PostPosted: Fri Oct 19, 2007 7:26 am
Mate I would stick with your original idea of getting a Rover front cut. Sure the gear inside it aint new but you get lots of other funky stuff like new dash, a/c and efi. Speak to Steve at Brixworx, he is a nice enough and a helpful bloke.
PostPosted: Fri Oct 19, 2007 11:36 am
That sounds like a full resto. Unless you do the work yourself it is likely to be costly. Unless the car has sentimental value to you it might be cheaper and easier to get another Mini that someone else has already spent the money on.
Pete
PostPosted: Fri Oct 19, 2007 1:06 pm
no one has asked or tried to diagnose problems, i will have a tank in about a week,
PostPosted: Thu Nov 15, 2007 8:30 pm
thanks for the feed back.
after consulting with Steve at Brickworx I have decided to go with the frontcut.
hope to have it on the road again before xmas
Users browsing this forum: watsupskip and 73 guests
