It is currently Mon Jul 28, 2025 7:49 am
 Post subject: LS wheel look like
PostPosted: Fri Nov 16, 2007 9:39 am
What does the original Wheel off an 1978 LS look like?
PostPosted: Fri Nov 16, 2007 9:42 am
if no one else has got a foto here by 2morrow ill take a pic of the original ones of my LS and put it up, im not going to be home till like 11 tonite, but if u just search LS1275 in images u should be able to find one
Hi-Ho Silver LS1275
PostPosted: Fri Nov 16, 2007 9:55 am
This was the original off my 1977 LS..
PostPosted: Fri Nov 16, 2007 10:29 am
Sorry for the misunderstanding i should have been a bit more specific, i ment road wheels which i belive are 12".
Also what wheel do you have as a spare that will fit under the larger fuel tank?
PostPosted: Fri Nov 16, 2007 10:35 am
I was tossing up which wheel you meant but got it wrong.. :?
I have 12" road wheels on the LS and the spare is also a 12" but I have made a boot shelf like the pic below.. Since this photo was taken I have fitted a 35ltr tank and the spare still fits in ok..
PostPosted: Fri Nov 16, 2007 10:36 am
You mean 1275 LS.
The original 12" steel wheel will still fit in boot under the bigger tank (tanks are shaped to take the spare).
PostPosted: Fri Nov 16, 2007 10:43 am
G'day Scott.. I heard a rumour you had been run out of town but I guess that rumour I started wasn't true after all.. :wink:
If Toasted if referring to a 1275 LS then I will take back all that I have written and posted about this subject... :?
PostPosted: Fri Nov 16, 2007 10:53 am
You can see the original wheels here:
http://www.ausmini.com/forums/viewtopic.php?t=35579&highlight=1275
Basically they are a steel 12" rim with a hubcap that fits on and is retained by the wheel nuts.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Nov 16, 2007 11:11 am
Online
The original tyres were 145/70-12. If you fit common 145/12 the spare won't fit in the boot, unless you downsize the battery... :lol:
PostPosted: Sat Nov 17, 2007 7:31 am
hey heres the original wheels and caps off the my LS1275, theres also a boot shot showing the performance minilite, its a 12x5 with 145/70R12
its a pretty snug fit, like it sits nicely in there and looks like it should be there but it is still quite tight, u cant fit anything between the tire and fuel tank (tank is larger one)
Hi-Ho Silver LS1275
PostPosted: Sat Nov 17, 2007 9:37 am
poeee wrote:
You mean 1275 LS.
Yes 1275LS
Ive tried to put one of my 12x5 wheels in there and it didn't fit really well. What profile tyre is that?
thats the same steel rim that i have in my boot i was wondering and thought it would have been wheel like the S model.
Anyway thanks again and ill be using that rim i have as my spare unless i make the boot floor deeper.
THANKS ALL!
Users browsing this forum: drmini in aust and 89 guests
