It is currently Wed Jul 16, 2025 9:30 pm
Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Wed Nov 28, 2007 2:50 pm
Ok went and grabbed some of the brake parts and took a snap.
Also I checked the car, there doesn't appear to be a spacer. Just a hub. I'll jack the car up and unbolt a wheel to have a proper look later, too hot right now!
PostPosted: Wed Nov 28, 2007 2:57 pm
Is that pic of the Metro Turbo hardware? - calipers, swivel hub and drive flange
-Alan
PostPosted: Wed Nov 28, 2007 3:28 pm
This space for rent
slinkey inc wrote:
Also I have sexy stainless steel braided brake hose which came with the car (bought brand new in the UK) but I have a funny feeling they won't be legal. :(
From your pic, I don't think those ones are legal. I think the ADR'd ones have yellow tags with the manufacture date on them, but don't quote me on that ;)
PostPosted: Wed Nov 28, 2007 4:19 pm
The swivel hubs on the car seem to be normal Mini drum hubs but the steering arms look funny (Metro, anybody??)
The swivel hubs in the bin are Metro items.
Those brake lines could be passed if the engineer accepts them, but he would be stupid to if they are not ADR compliant.......I will check mine when I get home.
The gap between the adapter plate and the disc face seems to be non-existent - do they touch?
PostPosted: Wed Nov 28, 2007 7:24 pm
Give Ash some flowers Nick .
That subframe / engine bay does look sexy! 8)
Keep us updated
PostPosted: Wed Nov 28, 2007 8:59 pm
No they don't touch, very small gap though. They were professionally made (obviously) and designed. We'll see what happens, if all goes dodgy, I have Metro hubs to play with.
PostPosted: Sun Apr 06, 2008 9:41 pm
Quick update. Over the looooong summer holidays I got a huge amount of body work done, learnt to mig weld and had a lot of fun.
I sent my motor and a subframe off to Ben (92 on here) for some surgery and got it back yesterday. It's a work of art I reckon!
Although I haven't been on Ausmini much, or to any Hotbricks meetings recently, I'm still very much into Mini's, just with uni (started my Bachelor of Mechatronic Engineering at Adelaide Uni) and work I don't find a lot of Ausmini time.
I've got some holidays coming up (6 weeks into uni and now we got a 2 week break...cool) so I'm going to test fit the engine and frame, chop and cut as much as necessary and then get the frame powdercoated, silver probably.
PostPosted: Mon Apr 07, 2008 10:02 am
Nice. A couple of weeks of work should see it progress nicely 8)
PostPosted: Mon Apr 07, 2008 8:59 pm
Good luck with it all, progress pics are always welcome :)
PostPosted: Mon Apr 07, 2008 11:48 pm
Any chance of some pics of the subframe from other angles?
-Alan
PostPosted: Tue Apr 08, 2008 7:40 am
Yes, it would be interesting to have a look!
PostPosted: Tue Apr 08, 2008 9:27 pm
Other angles?
Yeah sure, I realised after posting that 90% of the work is forward of the suspension towers. :roll:
When I find the time, maybe tommorow, I'll take some more photos otherwise Thursday probably.
Also I should say that the engine is mounted in such a postion as to give equal length drive shafts with my equaliser shaft from a 4AGE 20v (I think) motor. :)
PostPosted: Mon Apr 14, 2008 6:40 pm
Took the motor off the 'frame today then took the existing subframe out of the 'shell. Most of the front of the 'frame is bolted together to make it easy for installation (luckily for me), so I test fitted the 'frame minus all the extra bits and found where I need to bend and cut. Marked it then took the 'frame out again.
I whacked it back together again for some photos though.
Also, a pic of the equaliser shaft and bracket to hold it there.
PostPosted: Mon Apr 14, 2008 6:44 pm
What's the rationale behind having the subframe bolted to the towers vs welded to them?
-Alan
PostPosted: Mon Apr 14, 2008 6:51 pm
Pretty much that^^^
Having said that, I didn't make the frame. However if the frame didn't come appart, I would have had to guesstimate where to cut etc to make it fit.
But since it unbolts I put the back half in, marked where the cutting (the radiator shroud) has to be done, also some good ol' hammering needs to be done to some areas but otherwise it's a nice fit with mods being all of the 'can weld it back in to make it original easily again' - but the subframe is Starlet for life! 8)
Users browsing this forum: No registered users and 25 guests
