It is currently Mon Jul 28, 2025 3:48 am
PostPosted: Mon Dec 03, 2007 7:53 pm
hi, how hard is it to get a diff ratio under 3.44. i'm wanting a diff for the highway. i have noticed that some diff ratios only suit a+ gearbox casings. will they fit both.
PostPosted: Mon Dec 03, 2007 7:55 pm
Yes the A+ ones will fit both boxes but teeth angles are different so you need both the pinion and crownwheel. :wink:
PostPosted: Mon Dec 03, 2007 8:31 pm
is the lower ratios harder to get
PostPosted: Mon Dec 03, 2007 8:33 pm
Yes very hard to find and expensive.
PostPosted: Mon Dec 03, 2007 8:35 pm
No minis were sold here with lower than a 3.44.
PostPosted: Mon Dec 03, 2007 8:46 pm
contact brickworx or miniimports
PostPosted: Tue Dec 04, 2007 4:15 pm
thanks, i will try and contact them. does anyone run a low ratio diff, is it worth getting one for a 1380. i'm wanting it for cruising highways with little revs.
PostPosted: Tue Dec 04, 2007 4:48 pm
yes i run a 3.2:1 with my 1510cc engine & it`s good for that but you really need to have the grunt to pull such a tall gear.
I actually hate small engines with tall gearing, it just makes them dohey pigs :-)
& just so you don`t get all reved up & set up & ready to go for the swap only to come to a grinding halt,,,, you will need the larger diameter bearing retainer to fit the larger pinion gear into... The later type retainer for use with the tall gear set are made with a bigger hole in the guts so the big pinion gear fits & also utilises only 3 of the 4 "usual" mounting bolts.
oky-doky???
PostPosted: Tue Dec 04, 2007 5:07 pm
& just so you don`t get all reved up & set up & ready to go for the swap only to come to a grinding halt,,,, you will need the lager diameter bearing retainer to fit the larger pinion gear into... The later type retainer for use with the tall gear set are made with a bigger hole in the guts so the big pinion gear fits & also utilises only 3 of the 4 "usual" mounting bolts.
oky-doky???
Read that again...grinding it out is a dog of a job! although, a drum sander on a press helps.
 Post subject: 2.9
PostPosted: Tue Dec 04, 2007 5:28 pm
hi i have a 2.9 ratio in my car. really good on the highway...(3100rpm at 100km/h
i know what you other guys say about it though but its my car and i luv it. lol :D :D
i like to drive on rails
PostPosted: Tue Dec 04, 2007 7:59 pm
so 3.44 gives you the alround package
Users browsing this forum: Majestic-12 [Bot] and 77 guests
