It is currently Sat Jul 19, 2025 12:12 am
PostPosted: Thu Jan 13, 2005 11:11 am
Hi
I'm trying to rebuild an old mini and am having problems getting the engine to start. The problem seems to be from the carburettor onwards (as opposed to fuel line/pump problems). I have tried pouring fuel into the carbie, and it does get through to the engine but it still will not start. I have checked the spark plugs and distributor and they are working fine. There is a slight loss of pressure in two of the cylinders but been told that this would not be the source of the problem.
can anyone help?
PostPosted: Thu Jan 13, 2005 11:16 am
Check the timing - rotor in the distributor pointing to 2 o'clock with #1 cylinder TDC and flywheel timing marks at 1/4
David L
PostPosted: Thu Jan 13, 2005 11:33 am
Whether it is obvious or not, check you have good fuel, mot what was left in it 30 years ago.
PostPosted: Thu Jan 13, 2005 11:56 am
I would go with checking the timing on the dizzy like said make sure rotor button is at #1 Cylinder lead when #1 is on compression stroke.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Thu Jan 13, 2005 12:11 pm
Put your suburb in the profile and maybe someone living close by could have a look at it for you.
mutant mini 1380cc '73 UK imp-Chroma Lusion-leather interior-8 x 300W Diamond Audio Dual Voice Coil 8" subs, Phoenix Gold 4 chnl amp, Pioneer 7550 DVD, 2x Phoenix Gold A1.800d MonoBlock Amp, Focal Utopia splits, 14" chrome rims 195/40/14 tyres
