It is currently Mon Jul 28, 2025 1:31 am
 Post subject: mini lites
PostPosted: Thu Feb 28, 2008 4:00 pm
hey i have a set or 12" mini lites and im thinking or upgrading to 13"
is it worth it, is thier much involved ?
thanks
PostPosted: Thu Feb 28, 2008 6:41 pm
Is there anything anyone can say here that will make your mind up definitely?
Theres pros and cons of each setup.
Do you have the money to upgrade? A cheap set of 13s will set you back maybe $100 per tyre and $100 for rims (all new). A better setup would be rims and better tyres than cheapies, but may also include guard cutting, flares, brakes (if you're still on drums get discs).
When I decided to go 13s on the project car, I've also put in replacment cones, hi-los, new balljoints, disc rotors, drums, pads, wheel bearings, suspension rubbers, and the bearings in the raduis arms. Ditched the old shocks too, and fitted an adjustable rear end. Originanally I rebuilt tome 4 pot vented brakes, but didnt use them in the end.
Nothing I replaced was done because it was stuffed outright, would've been fine for the old ten inch wheels or even 12s, but for the jump to 13s I thought with all the extra weight and offset of the wheels I'd be better starting with a new setup so I can better gauge how it degrades over time.
For the mini driven more regularly, I run 12s with 145s. Cheap, light, look good, no crazy guard work or expensive arches. It just makes more sense to me that way.
:D
PostPosted: Thu Feb 28, 2008 6:48 pm
not worth it, gotta cut the guards, it adds more unsprung weight and tyres are more expensive.
12's are probably the best way to go with a street mini.
PostPosted: Thu Feb 28, 2008 7:52 pm
well i allready have the disc brakes, hi-lows , new shocks
i got the car with these wheels i saw the 13 " at mini clinic so yeah :S not sure
PostPosted: Thu Feb 28, 2008 8:07 pm
Die Die Die!!
i think you only have to cut the guards if its over 6" wide ?
PostPosted: Thu Feb 28, 2008 8:09 pm
6" wide wheels ?
im not sure how wide they are lol
but should find out b4 i buy them right
PostPosted: Thu Feb 28, 2008 8:11 pm
Die Die Die!!
well knowing the dimensions of your rims will come in hadny at sometime or another.. so yes..
PostPosted: Thu Feb 28, 2008 8:17 pm
show me the wheels first and Ill tell you if its worth the expence or the time
The 12's may only need a good clean up rather the expence and time. You don't get any driving benifit from going from12's to 13 if not backwards. Just more pain or looks
PostPosted: Thu Feb 28, 2008 8:38 pm
its the mini lite ones deep dish that looks like the ones i have just bigger and deeper
PostPosted: Thu Feb 28, 2008 10:27 pm
the grass isnt greener
there are some advantages in the low profile tyres cornering
but they're outweighed by the increased weight
you can run 13's without cutting the guards if you run the suspension height really high which looks stupid
i cant dump my mini with 13's too low or it scrapes on driveways and bigger bumps/corners
PostPosted: Fri Feb 29, 2008 1:00 am
My mini has 12's and fairly low profile tyres, and it rides about as low as i'll let it... (it wouldn't pass a road-worthy), but I reckon you'd like the look i've got... it only ever scrapes when i have a passenger and I am being silly.
seriously, 12's are fine just lower the car and make the front slightly smaller profile than the back... (I didn't just say that as i think it is illegal)
Daniel the concreter (for now)
1974 mini 1100, fully sick rims, disk brakes, new paint, air conditioning, cruise control,v-tech... wishful thinking
PostPosted: Fri Feb 29, 2008 12:44 pm
You are talking about going to 13x7's (Commonly the deep dish variety)
They look good, but look at the overall cost - they'll set you back at least ~$1400 including tires then you will need to cut your guards and get arches to suit.
It wont handle as well as it did on the 12's due to the increased weight and offset used to fit them and it will be slower to accelerate, you'll use more fuel and it wont go as fast top end either. Wheel bearings will also wear out faster.
PostPosted: Fri Feb 29, 2008 1:18 pm
keep your 12's but clean them up...re paint the inside section and really bling the deep dish and outer sections. A lick of paint and a blinging does wonders
PostPosted: Fri Feb 29, 2008 2:50 pm
I ave 13x7's on mine (my brothers :lol: )
I found when I had 12's on them to get it through blue slip that it handled better. It was alot light in steering and smoother on the road.
The thing I like about my fat wheels though is it looks like it will eat you.
From some perspective it looks weird when you go from looking at a mini with 10's or 12's on it to looking at a mini with 13x7's. It looks like a child with shoes that are too big. But it grows on you and I like it.
I suggest, clean your wheels up first, put some tyre black on them, maybe paint them a different colour, and see how you like it then, before investing lots of expense in 13's.
Talk is Cheap because Supply Exceeds Demand
mattsmadmini wrote:
you've got awesome norbles
PostPosted: Mon Apr 21, 2008 6:36 pm
hey people can anyone tell me exactly where req cutting on the guards and how much??? diagrams would be great.... thinkin of goin up to 13's too......
cheers 4 n e help... :D
1978 1275 LS silver 3rd palce mini Oz50 LS,SS,GT Class
1970 MORRIS MINI K 1100 3rd place mini50 pre '71 Class
Rover BBQ..... ;)
