It is currently Mon Aug 18, 2025 6:25 am
PostPosted: Tue Mar 04, 2008 4:54 pm
g'day yes you have to have your windows out as the rubbers help hold the lining in.....i did mine and wish that i had another go at doing it as it has a few creases any way.........do your windscreens first and pull firm but not too tight.... then work down both sides slowly pulling out creases{not too hard or you will stretch the vinal} and gluing and then the rubber.... it will take a while but persiver and good luck.........
PostPosted: Tue Mar 04, 2008 5:47 pm
I have done it and have to say its not a hard job, however i do have an upholstery background.
Take all glass out, and use a heat gun or hair dryer to help gat creases out.
I say give it a go. Be paient with it.
Its only material, you can make it do what you want.
Best of luck.
Steve - did your set have the bit I mentioned earlier that was missing from mine?
PostPosted: Tue Mar 04, 2008 5:51 pm
winabbey wrote:
lilmatti,
I suggest you check the contents of the kit. I purchased one a few months ago and it didn't come with the rectangular piece that runs under the back window between the pillars. I managed to convince the seller to supply the extra piece but he wasn't particularly enthusiastic about it and said that he would have to cover the extra cost. I tried to point out that this section was a standard part of the interior headlining and needed to match the other headlining material.
Good luck.
P.S. I haven't fitted mine yet so can't help in that regard.
Doug
did you buy it from the same seller?... any1 know what order the bows go? i dont have the same colours as the one in the other forum
PostPosted: Tue Mar 04, 2008 6:01 pm
Yeah mine had everything, i also paid a little extra and got some made up for the two front pillars that run down between the windscreen.
Here's a pic of my kit.
Steve
Classic Not Plastic
PostPosted: Tue Mar 04, 2008 6:33 pm
Sounds like my polite message was heard. What puzzled me at the time I purchased mine is that I had seen those Mini one's sold on eBay for some time and most Mini enthusiasts would know that piece is in the same material and required, so why would he act a bit surprised initially when he said it wasn't meant to be part of the kit? Anyway, great that it's now included.
Like lot's of others, if you can take some photos in between the 'stretching and gluing' and stick them up here I'm sure it would be of great benefit to the forum.
PostPosted: Sat Apr 19, 2008 3:11 pm
lilmatti_69 wrote:
hey i just checked my bows and instead of this:
Red
White
White
Black
Blue
Yellow
i have this, not in correct order
Yellow
yellow
orange
brown
red
Nothing.
is this the same as everyone else? what order do they go in?
Hey sorry to bring up a old post but im about to install my headlining, does anyone know what order there bars go in?
PostPosted: Sat Apr 19, 2008 5:53 pm
High heel ninja
Just pay a trimmer to put it in, its not expensive, PM trimm he's a damn good trimmer thats very reasonably priced, if you fit it yourself & stuff it up you will hate yourself.
Doogie
PostPosted: Sat Apr 19, 2008 6:16 pm
Doogie
Thanks Brother
I've PM'd him so ill wait for a reply
Users browsing this forum: No registered users and 212 guests
