It is currently Wed Aug 20, 2025 1:28 pm
PostPosted: Tue Mar 11, 2008 8:19 pm
Is there an easy way to get it back onto the engine block ? any tips ? hints?
(I was bleeding the clutch, undid the engine steady rod at the engine, so I could get to the bleed nipple)
-- Simon // VMCI Member 2674 --
PostPosted: Tue Mar 11, 2008 8:29 pm
I assume it's a remote change, and won't rock enough.
Undo the 4 bolts about 2 or 3 turns where the remote extension bolts onto the box.
Fit the steady and retighten. :wink:
PostPosted: Tue Mar 11, 2008 8:34 pm
Give Ash some flowers Nick .
It's a PITA, just hang in there :wink:
I lost count of how many times I tried to start it when I last pulled it off (and I have nolethane bushes).
PostPosted: Tue Mar 11, 2008 8:54 pm
hmm, u could try a quick clamp around the other way as a spreader, one end on the fire wall/ pedal box area and one on the head...
Not sure if it would work but its worth a try :)
PostPosted: Tue Mar 11, 2008 8:58 pm
Thanks.
I greatly appreciate the help.
It doesn't have enough rock, so will try the 4 bolts for the remote and see how that goes.
PostPosted: Tue Mar 11, 2008 9:06 pm
block of wood and a jack under the GB. move the motor to the position you need. Tighten steady up and remove jack(very important, don't laugh it has been done before! :lol: )
Aaron
PostPosted: Tue Mar 11, 2008 9:15 pm
aaron ... use the jack as a spreader to move the engine forward ?
PostPosted: Wed Mar 12, 2008 2:17 pm
no, just to lift the back of the motor - thereby tilting it forward
PostPosted: Wed Mar 12, 2008 2:27 pm
Thanks Simon.
Users browsing this forum: Bing [Bot] and 189 guests
