It is currently Sat Aug 16, 2025 2:13 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Dec 23, 2007 7:03 am
Lillee wrote:
My car is now pretty darn quiet for 120hp. 95% of the sound is now coming from the intake :oops:
Yes, it can be the case that induction noise is louder than the exhaust, especially with a Weber or Dellorto.
I was pinged for excessive noise once at a meeting at Philip Island. The EPA guy told me to forget about the exhaust because the noise was a combination of straight cut gear whine and induction noise. A hastily made up baffle box from a cardboard beer carton, fitted under the bonnet and around the Weber reduced the noise to an acceptable level. :lol:
Curly
PostPosted: Sun Dec 23, 2007 8:42 am
I used to run a straight through 2" system and the car was fairly noisy but I am using a two piece RC-40 now and that has quietened it down a lot but still has a nice tone to it.
Makes it a nicer car to drive over distance now.
PostPosted: Sun Dec 23, 2007 9:30 am
Slow-Po
My original exhaust was way too loud, could couldn't talk at 110kph, and you could actually feel the tingling in you ears. I replaced the muffler with a larger straight through muffler which sounds much better and got a couple of hp out of it as a bonus.
PostPosted: Sun Dec 23, 2007 9:38 am
tinymorris1969 wrote:
:D mines only got the hotday and 2inch all the way with twin tail pipes on the back and it is loud as....BUT I LOVE IT
Joe
Yours would probably do well up against the Toyoata Corona up and down main street Gulgong. Shorter cruising too. Each lap of town is less than a kilometre.
PostPosted: Sun Dec 23, 2007 10:36 am
Mokesta had the RC40 rear box only (you could see through it if the outlet wasn't bent) and I added a straight through Hot-dog (resonator) now it is really good.
Camilla just had the RC40 rear box and was too noisy.
PostPosted: Sun Dec 23, 2007 10:42 am
I is a mookenik
lol mike, i didnt make mine loud for that reason, when i bought mine it was loud with a cannon. i didnt like it so i juz got the straight through piping cause the benefit of a loud exhurst is people on the road can hear u coming and will look out for u
PostPosted: Sun Dec 23, 2007 11:15 am
:lol: I know Joe, I was just pulling your leg. Just make sure that those that hear you coming and look out for you arn't also driving cars with blue and red flashing lights.
I like a car with a "note" as much as anyone else but I have grown too old to really enjoy a car with "noise" - they both are quite different.
Merry Christmas Joe, and thanks for being a sport.
Mike
PostPosted: Sun Dec 23, 2007 10:53 pm
My Clubman GT was my only car for many years (standard exhaust and intake) and it was so noisy I could barely hear the stereo at 110kmh. Most of the noise came from the engine rather than the exhaust.
When I restore it I intend to Dynamat the whole thing to see if it makes it more liveable. It's nice to have that great exhaust note but I could do without the rest of the noise.
Pete
PostPosted: Mon Dec 24, 2007 9:22 am
My S has a nice tone to it, and you can hear it coming from a fair distance away, but oddly it doesn't sound anywhere near as loud as my K from inside the cabin.
The K was completely original with absolutely nothing changed, so it had stock exhaust.
Personally i like the purr of the engine, the hammering of the tappets and the whine of the gearbox :)
PostPosted: Mon Dec 24, 2007 9:58 am
If I use a 2 box system would I have to step up from 1 3/4 inch as planned or would it not be to restrictive ?
blokeinamoke wrote:
PostPosted: Mon Dec 24, 2007 2:46 pm
1 3/4" diameter is the perfect size for most modified mini motors, only those really worked motors, race engines and big bore strokers will need bigger, and even then 1 7/8" or 2" is the right size.
Stick to the 1 3/4"!!
M
PostPosted: Mon Dec 24, 2007 3:58 pm
You really don't know which size suits best until you dyno it.
My 1360 (282 cam) needs 2", the 1412 (RE13 cam) ran best with 1-7/8".
But a 1-3/4" is the best starting point for any road motor.
PostPosted: Fri Mar 21, 2008 1:29 pm
one other thing guys, did any of you guys have your cars tested, as in (forgot what they measure sound with / DB) test it with the meter,
i was going to get a 440mm (length) and 2" straight through muffler and see how that went, i was wandering if anyone had a part number of the one they used, local exhaust shop only had 2 they could order,
PostPosted: Fri Mar 21, 2008 8:46 pm
PostPosted: Fri Mar 21, 2008 9:06 pm
nothing wrong with a thread resarection, its like your old man with his erection, only comes up blue moon,
b sides mini topics aren't like womans clothing and how blue over black can be so 2 weeks ago
