It is currently Sat Aug 16, 2025 2:14 pm
 Post subject: Break bias
PostPosted: Fri Mar 21, 2008 11:28 am
Hi all, my current braking system is this;
Drum brakes all around and
a leaking brake bias as pictured below (it leaks out of the left end)
I'm upgrading to 7.5" Cooper discs and 60+thou rear spaced drums with correct sized shoes and 5/8th cylinders.
Seeing as I can't find a kit for my current bias I was wondering how hard it is to swap over to the rear type?
I have different MC as well that may suit the rear bias better than what's in the car now...your thoughts :?
And how much work is involved it changing the system over to the rear bias?
PostPosted: Fri Mar 21, 2008 12:52 pm
I would throw that old bias valve away (can't fix em) and find/fit a rear limiting valve from an early car instead.
I reckon any Mini with front discs regardless of M/C NEEDS 5/8" rear wheel cylinders. I found this out when emergency braking at 110KMH on the F3... :shock:
Most all Mini brake M/Cs are 0.70" bore anyway.
PostPosted: Fri Mar 21, 2008 2:00 pm
Perhaps the fault is due to misspelling?
PostPosted: Fri Mar 21, 2008 3:01 pm
I did spell check and it said it was fine :roll:
Like the white one pictured :?:
Is one type of MC better than another for my planed set up :?: I found this out when emergency braking at 110KMH on the F3... :shock:
Most all Mini brake M/Cs are 0.70" bore anyway. I meant the rear drums are +60 thou and I will be using 5/8th cylinders :wink:
This is the other type of MC I have. Would I be able to use this brake MC and my current clutch MC together, will they both fit side by side?
PostPosted: Fri Mar 21, 2008 3:50 pm
Bones "break" but cars "brake"
PostPosted: Fri Mar 21, 2008 4:55 pm
Q1 yes. Sorry, I didn't pay attention to the pic.
Q2 not really.
Q3 yes they will.
+.060" on the drum size makes bugger all difference in swept area or working radius..
PostPosted: Fri Mar 21, 2008 6:18 pm
That's punctuation not spelling :P haha I'm right :lol:
Thanks Doc. Will I have to change the brake lines from the fire wall to the rear subby to swap over the bias?
PostPosted: Fri Mar 21, 2008 6:22 pm
I didn't look at this thread before this - I thought it was about the need to have a short holiday in either Victoia or NSW. Hence the bias.
Glad the question has been answered now.
Mike
PostPosted: Fri Mar 21, 2008 6:38 pm
Doesn't that come down to grammar, not punctuation?
PostPosted: Fri Mar 21, 2008 6:58 pm
If I remember right a late Clubby has a tee near where the valve would go, but the early ones have a loop in the pipe to reach the valve. So yeah will probably need the main line replaced.
PostPosted: Fri Mar 21, 2008 7:36 pm
I differ slightly from the advice above:
1. Yes bin the engine bay valve. It's not a bias valve anyway, it's a fail safe device.
2. Rather than fit a second hand mini rear bias valve of dubious value, fit a new after market adjustable bias valve and spend some time out skidding and setting it correctly.
PostPosted: Fri Mar 21, 2008 8:18 pm
I'm Ernie , Where's Bert ?
who honestly gives a f*** :roll:
00' Forester GT
PostPosted: Fri Mar 21, 2008 9:30 pm
Yep you can get those from Wilwood among others, good idea.
Just remember in Oz it's illegal to have it accessible from in the car. :wink:
BTW no Mini here ever had a rear mounted bias valve, it was a pressure limiting valve....
<edit> typo
Last edited by drmini in aust on Sat Mar 22, 2008 6:30 am, edited 1 time in total.
PostPosted: Fri Mar 21, 2008 10:09 pm
Recently I noticed that the Rover 8.4" disc set up in the 1994 I imported had the larger (3/4") rear cylinders as standard. The horizontal, boosted MC must suit larger rear cylinders.
M
PostPosted: Sat Mar 22, 2008 1:50 pm
I have seen the rear type with a bolt in one of the holes that can be screwed in or out to regulate flow to the rear, that would act as an adjustable bias :wink: correct.
