lilmatti_69 wrote:
hey i was just wondering if the Mini RC40 twin muffler setup (with con pipe) from minisport will fit on standard clubman extractors or will i need to purchase new extractors?
thanks
There is no such thing as standard Clubman extractors. They all (apart from GT) had 1 carby and a cast exhaust manifold.
Waste of time IMO just putting a big 1-3/4 pipe and RC40 on that- unless you already have real extractors, buy some first.
A 3 into 1 is quieter than an LCB, also is less hassle to remove and refit.
The bit of pipe from extractors to the RC40 can be supplied by any exhaust shop. It's 1-3/4" OD exhaust pipe, Just measure up what you need.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
