It is currently Fri Jul 18, 2025 2:58 pm
Post new topic Reply to topic  [ 452 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 31  Next
PostPosted: Sat May 08, 2004 7:30 pm
$23.56 each for S rear wheel cyls at Karcraft (last year's catalog price)
He sells Brake Equipment brand (made in Italy)- I find their stuff OK. 8)
PostPosted: Sat May 08, 2004 7:35 pm
thanx kev, where do i get this years catalog?
lookin for another clubby
PostPosted: Sat May 08, 2004 8:00 pm
email [email protected] :wink:
PostPosted: Sun May 09, 2004 11:15 am
Any word on our eagerly awaited CD for doing this conversion?
regards
Kevin.
PostPosted: Sun May 09, 2004 12:05 pm
http://ausmini.tziworld.com/viewtopic.php?t=512
:? :cry:
PostPosted: Sun May 09, 2004 6:09 pm
i have pics if anyone wants some , just pm me ya email adress and ill send u sum
PostPosted: Wed May 19, 2004 7:36 pm
Here's a couple of pics of Honda Accord ventilated ones on a Mini.
Runs 13" wheels.
Pics courtesy of `animal' in Qld...
He has Qld Transport approval... :wink:
PostPosted: Thu May 20, 2004 6:36 pm
How much does it cost to convert a drum brake mini to Honda disc brakes?, thanks Tony
PostPosted: Thu May 20, 2004 6:58 pm
hey tony, so far mine have cost $170 but i got REAL lucky,
if u were to build them to my spec :
front balljoint kit $ 30 each ( 2needed)
front oil seals $3 each ( 4 needed)
cooper s wheel studs (rear) $3.50 each (8 needed)
new honda dba 191 rotor $90+ ( 2 needed)
honda calipers $40 each ( 2 needed)
new ferodo excel brake pads $80 set ( 4 pads )
front wheel spacers (19mm for 12 inch 25 mm for 10 inch) $70+
tapered wheel bearings $ 60 per kit ( 2 needed)
total:$630 this is a rough estimate for doing this conversion with ALL NEW parts, it will be alot cheaper with 2/hand rotors and non recoed drum hubs
PostPosted: Thu May 20, 2004 7:35 pm
If you shop discerningly at your friendly neighbourhood wreckers, you should be able to get a GOOD set of Honda discs, and the calipers, for $80 or so total. 8)
<edit> crap, it might even have good pads if you're lucky. :wink:
<edit 2> Then all you need is some spacers (19 or 25mm), some caliper mounting plates and a bit of machining to the drive flanges & discs.
I now machine the front of the `drum brake' type drive flange to 65mm dia, and bore the disc to suit, so it runs dead true. :)
Last edited by drmini in aust on Sun May 23, 2004 6:58 pm, edited 1 time in total.
PostPosted: Thu May 20, 2004 9:55 pm
Mine (pictured above) were a little cheaper...
Dics calipers from wreckers....free
Disc rotors from wreckers....free
4.5mm stainless backing plate and
19mm alloy spacer cut with h/p water
material suplied and cut....$100.00 (minimum cutting cost $100)
Pads 2nd hand(came with rotors and calipers) ....free
All up.....$100 8)
go stop...go..stop..go. stop..go...stop...Damn malls are crowded
PostPosted: Fri May 21, 2004 11:15 am
All up.....$100 8)
hey animal are your rotors 9.2 inch diameter? if so they should fit under 12inch wheels
PostPosted: Fri May 21, 2004 6:56 pm
From memory they are a 9'' rotor and yes you can fit 12''s on with no trouble....even standard steel 12's
PostPosted: Fri May 21, 2004 7:17 pm
Should stop a Mini way better than 7.5" S brakes (nothing special) or 8.4" Mini ones do..
er... what does an Accord weigh, anyhow? 900-1000kg?? More? :lol:
PostPosted: Fri May 21, 2004 7:34 pm
According to the compliance plate I swiped them from, 1145gvm...heavy little sucker.
for anyone that is unsure how good they are i can say that if not wearing a seat belt you would kiss the windscreen, if not for the steering wheel...as for the passenger...well...
