It is currently Sat Jul 19, 2025 5:59 am
PostPosted: Fri Jan 21, 2005 6:16 am
Original early 850 had pullcords, as in my first (`61) car.
Cooper 997 was the first here with the chromed crap inside levers (that break easy).
Later sliding doors, not sure. As I said my `64 850 (sold to Anton & Co) had windups when I got it. :wink:
PostPosted: Fri Jan 21, 2005 7:19 am
Yes this is true.
The 'Changeover' 850 had wind up doors one peice roof lining and also the Aussie style bootlid. I actually had sold one last year all original too.
 Post subject: Pull Cords
PostPosted: Fri Jan 21, 2005 7:24 am
supercharged 850 wrote:
I believe the pull cords were a "period accessory" but were not too common, especially here in Oz. Its easy to make your own (and I did :wink: ) but nothing looks as good as the originals. 8)
Now we wait for all the newbies to start asking.... "..pullcords??"
I think pull cords was the first method of opening sliding window doors they came up with in the UK. Not a period accessory.
Australia pioneered wind up window doors as the Doc has said and these were fitted fairly early because of our climate (and the need for 4X100 A/C).
BTW believe you can still buy a plastic Mini shell from South America. Maybe the Brits should have used them to combat salt induced metal rot.
PostPosted: Fri Jan 21, 2005 7:40 am
ridgey didge orig plastic mini ias photographed by me at the british motor heritage museum, no idea about the exploding on impact bit tho ;)
here's another pic - the first production mini.... wow
and the 3 monte cars ('66 should be there...) - *wipes tear from eye*
PostPosted: Fri Jan 21, 2005 7:50 am
Oz 850s were still made up until 66-67, these had windups and were badged `Morris Mini Minor'.
Gov't dep'ts took a bunch of them. :wink:
The one piece headliner came in in `64. My 850 had one, was original- the pattern matched the sun visors.
But the doors... in 64 we had yet to get windups. Someone swapped them.
Yep, Dr is right as usual, my 66 Morris Mini Minor originally had windy window doors, but i put slidey window doors in to save weight. My 64 850 has one piece headlining, slidey window doors with chrome lever (a la UK Cooper & Cooper S) and narrow number plate holder on the boot.
66-67 Morris Mini Minor was the base base model. Like Doc says, think fleet car. No heater, no fancy bits and pieces like the bumper over riders or deluxe grille, just the absolute bare minimum. Mine was originally Toga White with a red interior.
michael
PostPosted: Fri Jan 21, 2005 8:15 am
Don't confuse the Changeover Minis to the Government issue Poverty Pack MInis.
BMC would use whatever was available in the parts bins to make up the minis. During the changeover period Deluxe stuff was put on 850s. During the "Mk one" to "Mk two" Cooper 'S' changeover you can see early badges on old shells, mixes in upholstry, etc etc etc. Interesting enough I believe the Cooper 'S' was never officially identified in Australia as a Mk 1 or Mk 2. Just a Cooper 'S'. Probably helped in the changeover.
The commonly called Poverty Pack' were government fleet cars not only limited to the 850. I had a blue Mini 'K' pov pack. It didn't have the full gauges, just a speedo. No heater, plain upholstry & magic wand gear leaver (still all syrco box).
PostPosted: Fri Jan 21, 2005 8:51 am
let me guess, yours was 68-70 ish?
PostPosted: Fri Jan 21, 2005 8:55 am
Not exactly sure of the year Mickmini. Sorry.
PostPosted: Fri Jan 21, 2005 9:36 am
Lot's of weird stuff happened at the factory that was never documented.
Such as the change over models had bits of both cars...
And you'd probably guess right that it still happens. Some of the last EL Falcons got AU engines in them, seeing as they were producing AU motors well before the EL production run ended.
72 Clubman and a 75 Van.
PostPosted: Fri Jan 21, 2005 9:37 am
My Dad had one of these and yes I think that happens in all the Manufacturers.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Fri Jan 21, 2005 11:13 am
a mate of mine had a Mini with pull cords and we both thought they were crap. He ended up putting in levers
David L
PostPosted: Fri Jan 21, 2005 11:31 am
and then he found he didn't like the levers cause they break...
so he put wind up doors on bot found that they were bloody heavy and the cheap plastic flippers inside break regularly....
so he went to after market die cast units but wait!!! he found there was no easy way to mount these humongous castings onto a Masonite door card!!
So he bought an EL Falcon with an AU engine.....
(I'll stop now.... :? )
PostPosted: Fri Jan 21, 2005 2:15 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
9y was that a attempt at humour ????
makka
btw 9y dont use sarcasim some people think it is the lowest form of humour :(
PostPosted: Fri Jan 21, 2005 3:11 pm
it most certainly is not.... ;)
PostPosted: Fri Jan 21, 2005 3:41 pm
Hey you got to realise in the 1960's we didn't have the benefit of hindsight!! and when the lever handles broke you replaced it - it took a while to realise a design fault
David L
