It is currently Fri Jul 18, 2025 5:29 pm
 Post subject: How to tell if unleaded
PostPosted: Sat May 03, 2008 9:13 am
hey there, is there any way to tell if an 1275 A+ has an unleaded head without taking it off? I was told that it is from a late Rover, about '97 I think he said, engine no- 12A2EF77265256.
I always run BP ultimate in it.
PostPosted: Sat May 03, 2008 9:38 am
Casting number on head will be 12G940B.(up to 97)
or
if it is a 97 or later it will have an alternator mount of the thermostat end of the head
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sat May 03, 2008 12:23 pm
Rover started producing unleaded heads for the English market in 1989, and these were identified by a dab of green paint near the thermostat housing.
PostPosted: Sat May 03, 2008 1:34 pm
ok, the head has 12G940B on it I think, and looks like it has had a mount off it near the thermostat housing, but this could have changed when the altenator was put on it from my old 998? hmmm confused.
I think if it had had green paint on it it would have come off by now.
Does the build date, around '97 have any indication if its unleaded or not? ie, when where the majorirty of the heads unleaded?
PostPosted: Sat May 03, 2008 3:32 pm
According to my book, your engine is a very late rover engine, should defenitaly be unleaded.
PostPosted: Sat May 03, 2008 5:10 pm
You have me interested now, mini is an '89 and has been repainted so I can't see any green spots, I have the head off at the moment if that helps...
Noli Illegitimi Carborundum
PostPosted: Sat May 03, 2008 5:23 pm
Export (or Jap ones) don't have a green dot.
all Jap engines are unleaded i believe(from about 86)
PostPosted: Sat May 03, 2008 6:06 pm
yup but mine is an british motor out of an 89 metro
PostPosted: Mon May 12, 2008 10:17 pm
If the head is off it's easy - just have a look for seat inserts at the exhaust valves.
Users browsing this forum: No registered users and 111 guests
