Hi all
I was wondering if anyone could give me some tips on assembling these suckers?
Is there a trick to greasing em up?
use lots of grease to hold them together, glad wrap was suggested a little while ago, not a bad ideaIs there a way of knowing that my balls are no good?
aside from the paper cup, inspect them for uneven wear, measure them with calipers (21/32")And lastly has anyone ever replaced the inner boots with the drive shafts still in?
you can get the knobly bit off the shaft, but it's a pain. The cap comes with it, and you just bash it off the shaftIt looks like I could maybe squeeze them over the knobly bits and then maybe squish the cage through?
doubt it... last clubman ones I did, I removed the CV and did it from that end, I couldn't get the knobly bit off The inner boots seem to be ok I brought new ones with everything else so I probly should put em in.
yes, you should
If not they will be posted for sale, sans locking strips and grease.
thanks in advance Michael
