It is currently Mon Jul 28, 2025 6:18 am
Post new topic Reply to topic  [ 110 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Sat May 10, 2008 8:46 pm
gafmo wrote:
I think you have to rust proof your bench
Whats wrong with my kitchen bench? :shock:
PostPosted: Sat May 10, 2008 10:43 pm
your laminex is rusty :P
PostPosted: Sun May 11, 2008 5:45 pm
Thats why it is no longer in the kitchen and I stuck it in the garage. :lol:
Here is todays effort...
PostPosted: Sun May 11, 2008 5:46 pm
Give Ash some flowers Nick .
Another day or two should have it just about done. I'm impressed with how well it is working.
PostPosted: Sun May 11, 2008 6:09 pm
impressive
TUCK3R
PostPosted: Sun May 11, 2008 6:15 pm
Considering that all it involves is dunking it in a tub of vinegar it is not too bad.
You could clean it up in five minutes with a wire wheel but you still have to pull wires out of your shirt and sweep the floor, this is simple and easy as long as you have a week spare to do it. :D
PostPosted: Sun May 11, 2008 7:21 pm
seems to be working better than I expected. Then again, I always was an impatient b**stard. :cry:
PostPosted: Sun May 11, 2008 8:55 pm
Slow-Po
Look at what happens when you soak things (the one on left) in Coca-Cola overnight.
PostPosted: Sun May 11, 2008 10:20 pm
Is that with or without the Bundy speedy? :lol:
PostPosted: Sun May 11, 2008 10:24 pm
Bundy and vinegar - yuk :shock:
PostPosted: Sun May 11, 2008 10:53 pm
This space for rent
Hey Bloke, don't knock it 'till you've tried it :lol:
No, I haven't tried it, but I'm not knocking it
PostPosted: Mon May 12, 2008 2:40 am
The TIG
Really you should just build the electrolytic rust removal tank. That works brilliantly, it takes hours instead of days or weeks. And it's probably the cheapest to use anyway, as long as you have a few of the parts already kicking around. It's the best way to remove rust (other than cutting it out with a plasma cutter, lol).
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Mon May 12, 2008 5:43 pm
Todays effort...
There is no sign of the bolt coming loose. :cry:
PostPosted: Mon May 12, 2008 7:55 pm
This space for rent
Of course not, you haven't taken the nut off :!: :!:
PostPosted: Mon May 12, 2008 8:08 pm
I knew I was doing something wrong.
