It is currently Mon Jul 28, 2025 9:26 am
Post new topic Reply to topic  [ 110 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
PostPosted: Thu May 15, 2008 6:02 pm
I'd be interested to see the size of the vinegar bracket against a non rusted one.
Just to see if there is much in the way of a thickness change.
PostPosted: Thu May 15, 2008 6:14 pm
Morrie 1100 gets the Ausmini "Green" Award for being such a good environmental citizen :P
PostPosted: Fri May 16, 2008 7:15 pm
The vinegar part has now reached the point where it is starting to erode too much metal. The surface is deteriorating and is looking quite etched. I have given it a coating of oil and have now discontinued the experiment on this part.
The molasses is working well and starting to clean up the part. The steel bracket is starting to look silver, and a couple of other clean spots are breaking though.
PostPosted: Fri May 16, 2008 7:16 pm
Do I get the green award becasue I am dumping the waste on my grass? :shock:
PostPosted: Fri May 16, 2008 8:32 pm
Only if the grass is still green!!
Steve
PostPosted: Fri May 16, 2008 8:50 pm
This is Goulburn. The last time the grass was green was 2001.
PostPosted: Fri May 16, 2008 11:31 pm
Organic - CH3COOH ? You are in the clear 8)
I just disposed of 8 litres of copper sulphate down the toilet without thinking. ' now waiting for a knock on the door................. :oops:
PostPosted: Sat May 17, 2008 8:36 pm
The latest molasses result...
Slowly slowly...
PostPosted: Sat May 17, 2008 9:57 pm
Gadgets mini wrote:
Good thinking, I will stick it in the window to catch the morning sun.
that will give the neighbours something to talk about.
Especially if he's talking about his Beret :shock:
PostPosted: Sun May 18, 2008 9:52 pm
The Molasess is working slowly but the results are starting to show..
PostPosted: Mon May 19, 2008 7:46 pm
Resident Haemorrhoid
Oi Morris
wheres todays picture:twisted: :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
watching this whole experimenter thing is better than watching Big brother :lol: :lol: :lol: :lol: :lol:
mtsmini wrote:
Tombo wrote:
PostPosted: Mon May 19, 2008 8:13 pm
Gadgets mini wrote:
Oi Morris
Stop your nagging woman, I don't know why I ever married you. :P
I am starting to have doubts about the Molasses. It is just not doing the job. I think I need to get more heat onto it to improve things :cry: ...
PostPosted: Mon May 19, 2008 9:15 pm
More heat. What dilution ration did you use? Dont use 100% or it won't work very well. Ratio should be about 1:5 or greater. Some blokes pump air via a compressor into the solution every couple of days to speed up the process. I'm restoring a very rusty WW2 truck at the moment and using molasses exclusively. Great results but its very slow as my tub is not heated and fairly diluted. (I normally leave heavy rusted parts in for a couple of months ) I though about digging a hole in the ground, lining it with plastic, filling it up with molasses, and driving the truck into it.
Member VMCI #19
PostPosted: Mon May 19, 2008 9:22 pm
Milatsmadmini
OMG!
DO IT!
and take pics.... wat an awsome way to do it.... HA
PostPosted: Mon May 19, 2008 9:43 pm
On second thoughs, I need to dig a hole in the ground, line it with plastic, drive the truck into it, get out of the truck, then fill it up with molasses.
Member VMCI #19
