It is currently Fri Jul 18, 2025 4:32 pm
Post new topic Reply to topic  [ 452 posts ]  Go to page Previous  1 ... 23, 24, 25, 26, 27, 28, 29 ... 31  Next
PostPosted: Wed Jan 19, 2005 1:42 pm
Thanks Ty for the diagrams and pics
David L
PostPosted: Wed Jan 19, 2005 5:18 pm
If you guys are running 12" wheels or bigger I'd look at nuclear_mini's Camira setup. Better and stronger, IMO- has S track width and NO spacers on the drive flange. :wink:
Still uses drum brake uprights (swivel hubs), but the C/V and drive flange is S type (stronger).
PostPosted: Thu Jan 20, 2005 7:38 am
hey doc do the camira brakes use the S type outa cv joint :shock: with drum hub??
have you got any contact details for the seller, or is there someone selling them here? ive gotn some pics from a member member who bought them i think..
thx :)
GTi Turbo'd mini, abused daily
PostPosted: Thu Jan 20, 2005 8:17 am
bnicho wrote:
No, I'm using a pair of Mini Disk Brake hubs/uprights with the Cooper S callipers. So it all bolts together.
agreed - I was looking at my S disks the other day, and comparing with a set of 8.4"s I have, and it'd be pretty cheap to make a set of S disks if you buy a second hand set of 8.4"s - all you need is rotors (buy new anyway, ~$75 each) and calipers.... don't know how much a set of S calipers are...
PostPosted: Thu Jan 20, 2005 8:28 am
Cooper 'S' callipers? probably $500 a pair second hand.
PostPosted: Thu Jan 20, 2005 2:18 pm
Hi all,
Could someone send me a drawing or such with the measurments for the adaptor plate to fit 10 inch wheels please. :lol:
Also do you have to fit tapper wheel bearings for this mod or will the old ones be fine :?:
SORRY :oops:
E-mail is [email protected]
PostPosted: Thu Jan 20, 2005 3:11 pm
An email address in your profile would help
David L
PostPosted: Fri Jan 21, 2005 12:14 am
hi all could someone also send me drawings to fit 10 inch as well thanks heaps. :P
Harley
[email protected]
PostPosted: Fri Jan 21, 2005 7:25 am
go back through the pages and have a looksie, its been covered many times on how to make them fit 10' wheels.. :)
PostPosted: Fri Jan 21, 2005 7:51 pm
thank you so much to Pete and sandra and also david for emailing the pictures.
As to you 998 clubman i didn't ask how to fit them i was just asking for pictures becaus my win xp and norton block about nearly all posted but thanks for the support :wink:
PostPosted: Sun Jan 23, 2005 9:08 am
SK - Cooper S and Mini 8.4 use different drive flanges, so the S disk will not bolt up to the 8.4 drive flange. Probably an 8.4" disk machined down to 7.5" diameter, with 8.4 drive flanges and S callipers would work. That's what I want to try anyway. :wink:
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Jan 23, 2005 10:13 am
A big thankyou to David and Tyron for the pictures and diagrams for this conversion, they have helped me a lot. :D
Just one :?: To fit tapper wheel bearings in do you still use the spacer between the inner and outer bearings as I have not seen them before.
Cheers Pete
PostPosted: Sun Jan 23, 2005 6:08 pm
Cheers Pete
Yes the tapered rollers come with a spacer in the box. It's ground to thickness, to suit that particular pair of bearings. Don't mix it up with others, or run without it. 8)
PostPosted: Mon Jan 24, 2005 8:26 am
drmini ,
Thankyou for that I will go and get some before I finish.
Cheers Pete
PostPosted: Wed Feb 09, 2005 3:07 pm
Has anybody been using there Honda disks on the track :?:
I am wanting to know which pads you are using and whether you are happy with the way they are performing.
I was planning on using Bendix Ultimate pads....but it turns out to be a typo in their book and they say they have never made them or metal king pads for a Civic.
I will make sure I can buy a decent pad before I go and buy my setup as there is quite a few different calapers used with the DBA191 disks over that 1980 to 1990 period. :?
Can anybody help :wink:
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
Users browsing this forum: No registered users and 26 guests
