It is currently Sat Aug 02, 2025 12:39 pm
PostPosted: Tue May 27, 2008 6:30 am
Can anyone advice me the best way to remove front suspension lower support shaft
thanks
PostPosted: Tue May 27, 2008 8:10 am
This should be simply a matter of undoing the 3/8 unf nut on the end of the pivot bolt
and withdrawing it toward the front of the subframe.
But more often than not it is not that simple.
The bushes have a steel bush inside them which, due to corosion, seize on the pivot bolt
making them very difficult to remove.
Sometimes the section of the bolt where the bushes have been can be so badly coroded that it has to be replaced.
A good way of removing the pivot bolt is to use some heat to burn out the rubber bushes. Once the pivot bolt is removed from the subframe you can tackle the seized on bushes.
Moral of the story? USE ANTI SEIZE ON THE PIVOT BOLT BUSH AREA when assembling!
PostPosted: Tue May 27, 2008 8:23 am
By the looks of that rubber I think the heat will be your only option as it looks pretty well stuck in there. I had to cut one of mine off due to the bush being stuck on there...
Good Luck
Rob Forsyth
Miniot!!
PostPosted: Tue May 27, 2008 8:45 am
Lots of WD40 and a BFH should get it.
PostPosted: Tue May 27, 2008 10:47 am
:D My thoughts exactally .... :idea: oh and a Big Pry Bar or flat screw driver for prying and hitting :!:
PostPosted: Tue May 27, 2008 7:38 pm
just as i thought lots of brute force. :roll:
thanks guys.
