It is currently Tue Jul 22, 2025 5:33 pm
 Post subject: ahhhh rust
PostPosted: Tue May 27, 2008 9:44 pm
ok... i have a slight rust problem and need some advice from those wiser than me(not too hard)
what is the best approach to removing surface rust on the roof gutters on a clubman- i have heard wire brushes work well...are there any other solutions??? cheers
leighton
PostPosted: Tue May 27, 2008 10:00 pm
Mate i have just done it to mine. Wire wheels are great, but extremely unsafe so be very careful when using one.
I use POR-15 products for rust on my car. Google it - Awesome stuff.
PostPosted: Tue May 27, 2008 10:44 pm
Forum Graffiti
I've recently done my Mini ones and I've just done the ones on my Morris. Make sure you get any bog/putty/seam sealer out of the seam... Get something sharp and pointy and dig it out as water gets in behind and rusts out the seam :x Both my cars were like this. Then I use either a wire brush or wheel, give it a good thorough brushing, rust converter, prime, etc. Depending on the severeness of the rust, it may need more than a wire brush and converter...
PostPosted: Wed May 28, 2008 7:11 am
This is what I used after using a small wire wheel. A small screwdriver with a bend to get at the seams:
Regards
Dave K.
PostPosted: Wed May 28, 2008 7:46 am
Thats a great pic - very artistic. I like the wire wheel marks too 8)
PostPosted: Wed May 28, 2008 9:12 am
I use a broken hacksaw blade to scrape out the rain gutters. Works a treat and you can get it all the corners with it. Use flexible seam sealer to reseal, not bog!
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu May 29, 2008 12:22 am
How about Sikaflex? Is this good?
1964 Morris Mini 850 - G13b gti powered - classic yet practical
1968 Morris Minimatic - 1100cc - classic & breakable
Sun Certified Java Programmer v5 310-055
PostPosted: Thu May 29, 2008 1:01 am
same thing, sikaflex is 'a' leading brand of flexible sealer, possibly 'the' leading brand. The modern products are all very good though, I can't remember a complaint about any brand or product
Noli Illegitimi Carborundum
PostPosted: Thu May 29, 2008 11:27 am
Yep, Sikaflex is very good. It's important that it's a quality paintable type, not the cheap crap from Bunnings for bathrooms etc.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
