It is currently Fri Jul 18, 2025 5:39 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jan 26, 2005 8:01 am
Thanks guys,
Very useful. Given that I have some angle rather than strip available, I think I'll try something like Docs.
I'll let you know how it goes.
KB
PostPosted: Wed Jan 26, 2005 8:06 am
Kev, mine was made from scrap, that's why it has holes in the ends..
All you need is a piece of angle, and a U bolt or similar. :wink:
PostPosted: Wed Jan 26, 2005 8:24 am
i went to supercrap and bought a set of trailer brackets. Cut one leg off both and drilled a hole to suit the size ubolt. I attached them on 2 & 4 with a bit of chain and lifted from that using my right biceps muscule, well maybe it was pulling the chain attched to the pulley.... I ended up using one to put the engine in and it worked a treat. Easy and cheap to make, rather than having to weld anything up.
Aaron
 Post subject: Buccaneers
PostPosted: Wed Jan 26, 2005 8:50 am
Pics of mine- note the forward angle the motor sits at.. :wink:
Neat Doc, so what do you use the ears on the lifting bracket for???
skssgn :!: ....I think 6 lifts might have been enough....look how flattened your U Bolt is.....might pay to whack a bit of reinforcing around it!! :wink:
 Post subject: Re: Buccaneers
PostPosted: Wed Jan 26, 2005 9:30 am
LOL - you've never seen a steering rack U bolt - trust me, it's meant to be that way - I don't think any U bold would flatten like that without something very very abnormal going on...
angus, the other two are my 6" flat screwdriver, and my torque wrench ;)
I don't like using the head studs, cos I sometimes need to lift or remove a motor without wanting to re-torque the head - and I get nervous about breaking them....
PostPosted: Wed Jan 26, 2005 10:24 am
As I said this bracket was made from scrap. It used to be a lift bracket in the roof of my neighbour's garage.. 20 years ago! :lol:
Actually a bit of BIG angle would be the go- 2 holes for the studs, grind to clear middle stud, drill or burn a hole in the top leg of it for the hook!
I'll stick to using the U-bolt- it's quicker to weld things than cut big holes.. :lol:
PostPosted: Wed Jan 26, 2005 5:06 pm
That's pretty much what I will go with, angle and a D shackle piece welded on. I did'nt want a real big piece of angle though coz I was worried the thread on the head studs isn't that thick to take up the thickness of the angle.
KB
PostPosted: Wed Jan 26, 2005 9:21 pm
gosh, i just used some rope and wrapped it around the engine at both sides and then tied knots in it and used a block and chain.
PostPosted: Wed Jan 26, 2005 9:33 pm
Yeah we all did that once upon a time, but if you make a habit of pulling 'em out, a bracket is a handy piece of gear. Safer too..:wink:
PostPosted: Wed Jan 26, 2005 9:34 pm
agreed, i don't plan on doing that so often heh :)
PostPosted: Wed Jan 26, 2005 11:02 pm
Well,
I built my engine lifting bracket tonight. Have taken some photos but have yet to conquer FTP'ing to host the photos.
After I get that sorted, I'll post some photo's.
What do you guys use for FTP to servers?
I'm with bigpond and want something as simple to use as possible!
PostPosted: Wed Jan 26, 2005 11:37 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
photo bucket
makka
PostPosted: Thu Jan 27, 2005 4:46 pm
Voila -
Knocked it up last night, will let you know how it goes when the engine comes out (hopefully the weekend).
KBImage
PostPosted: Thu Jan 27, 2005 7:39 pm
Is Don, Is Good.... 8) :wink:
PostPosted: Thu Jan 27, 2005 8:46 pm
resident alien
resident alien
I use WS_FTPLE. When you install it choose the options to say your a teacher at a school using it for work at school as it's a "Limited Edition" it's free as long as you choose these options otherwise it won't install. Simple and easy to use.
Users browsing this forum: No registered users and 112 guests
