It is currently Tue Jul 22, 2025 7:47 am
 Post subject: Temp Sender
PostPosted: Sun Jun 08, 2008 9:41 pm
Hi Guys
This would be easier to explain with pics, but I don't have any, so words will have to do.
The temperature sender for my temp gauge is broken. I don't know what type it is called, so I will try to explain it. The part from the block to the gauge looks like coiled wire, and it has snapped of where it enters the fitting into the block. Does this make sense?
Where can I get a new one, and whats it called?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Jun 08, 2008 9:47 pm
Does the wire from the dash to the sender in the block look like it ends with an electrical connection (like a spade connector) ?
Or does it just bury itself in the sender like it was made with it as one unit?
If it does the broken 'wire' will be hollow.
PostPosted: Sun Jun 08, 2008 10:07 pm
From your description it is a capillary type. It's actually a tube filled with ?? which expands up to the aftermarket gauge and operates it much as a mechanical pressure gauge works.
It really is a part of the gauge, you will probably need to buy another.
These are more accurate than most electric gauges but the latter are easier to hook up, and less fragile.
PostPosted: Sun Jun 08, 2008 10:10 pm
Ether?
PostPosted: Sun Jun 08, 2008 10:12 pm
It's actually a tube filled with ?? /quote]Ether?
NFI.. can't remember, I have CRAFT disease. 8)
PostPosted: Sun Jun 08, 2008 10:21 pm
it doesn't have a connector, it just goes straight into the fitting. Here is a pic.
It goes into a smiths gauge. Don't really want to change it, would like to replace this wire thingy if possible.
[img][img]http://img84.imageshack.us/img84/9713/dsc00013bk3.th.jpg[/img][/img]
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Sun Jun 08, 2008 10:23 pm
Ether?
Alcohol actually - cheaper :roll: and less flammable and explosive
David L
PostPosted: Sun Jun 08, 2008 10:36 pm
Instrument repairers can repair/refill and recalibrate them for you pretty easily. it will cost about 150 dollars however...
Might be cheaper to get a repro smiths gauge with the exchange rate tickling the underside of 50 cents to the pound at the moment...
http://www.minispares.com/Product.aspx?pid=33772
PostPosted: Sun Jun 08, 2008 10:41 pm
Would it be just as easy to go electric?
Anyone got a gauge they want to sell me?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
Users browsing this forum: acarseldine and 89 guests
